Pcv hose valve and booster hose possition
I'd like to know where exactly is the the PCV valve hose and booster hose.
I think one is conected behind the base plate at the carburator and other at the intake between carb and distribuitor. But what is the right place for one and other. |
![]() Join Date: Feb 2011
Re: Pcv hose valve and booster hose possition
Well here's the booster hose; going to the vacuum tee, behind the carb from the brake booster.
MusicMan70 1961 GMC Suburban |
Here's where the pcv hose goes on my quadrajet. It's the big thick one in the middle under the fuel filter housing. Hope that's what you meant.
Thank you.
Also I think the metal line conected with a hose is for the advance? |
yes, I believe that is correct.
