Recommended gear oil '71 4WD Blazer
I wanted to check the fluids before the winter on my '71 Blazer 4WD. Can anyone advise what are the modern day equivalents of the recommended front and rear end gear oil, and the transfer case fluid? I would be topping off, not changing out fluid.
Thanks |
Re: Recommended gear oil '71 4WD Blazer
I would put 80W-90 In all of them with maybe a quart of ATF in the transmission/T-case for extremely cold weather.
#3 | |
The stock transfer case should be a NP205. I've seen GM specs for that unit that specify 80w-90 and Automatic Transmission Fluid (ATF). Nothing changed, just the spec printed by GM. I've been running ATF because it works better when its -20 fahrenheit and you need to push the snow off the driveway.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Would it make a difference if I have automatic transmission?
