Old 10-31-2011, 07:34 PM   #1
krazy_texan
krazy_texan's Avatar
Cant bleed brakes
ok i am at a loss here i have exhausted all options possible. And yes i have done numerous searches on this forum and on the net and cant come up with a single way to do this i can not for the life of me figure out how to bleed these brakes. I have tried the vacuum pumps i have tried the old fashioned way, and i have tried making the homemade pressure bleeder my problem with it is that i can not get it to seal on top of the master cylinder and i have tried makeing numerous types of caps for it. So please for the life of me someone help me out throw out your options or opinions or what have you cause i am at a loss right now and now that i am trying to park my car for the crappy season i am really needing my truck.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 10-31-2011, 07:37 PM   #2
shawno72
C/10 junkie
shawno72's Avatar
Re: Cant bleed brakes
Take it to Midas. They should have to correct cap for their pressure bleeder.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 10-31-2011, 07:53 PM   #3
brokenspoke
brokenspoke's Avatar
Are you not getting a pedal? If not are the calipers on the correct way?
brokenspoke is offline   Reply With Quote
Old 10-31-2011, 08:06 PM   #4
padresag
tell us what you did that you had to bleed the brakes and what kind of system
ron
padresag is offline   Reply With Quote
Old 10-31-2011, 08:12 PM   #5
krazy_texan
i completly replaced the entire brake system, new wheel cylinders, hoses, line and master cylinder
Krazy Texan
1990 v1500 suburban
Old 10-31-2011, 08:30 PM   #6
padresag
you more than likely just have a lot of air,.sometimes it takes a while. you need a pumper(another person) and start at the d/s rear and just keep at it until it comes
ron
Old 10-31-2011, 08:52 PM   #7
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Do you get any oil to the brake cylinders? In all four corners? Did you prime the master? Do you get any pedal at all?
Old 10-31-2011, 08:54 PM   #8
Harley1650
1963 C-10 BBC/Muncie 4 spd
Harley1650's Avatar
I converted everything. There was a LOT of air. My homade pressure bleeder uses a c clamp. It still took quite a bit to get all the air out
Harley1650 is offline   Reply With Quote
Old 10-31-2011, 09:12 PM   #9
krazy_texan
well i did put a dual master cylinder on it for safety purposes but i have done this before and never had and issue on other trucks so i am not sure i am not getting anything to any of the wheel cylinders i am going to try and bleed the master cylinder again and start all over from scratch but i am at the point now that i am going to have to wait until next weekend cause i start my new job tommorow. i did post this in the 67-72 board as well and someone suggested that i use a syringe to fill the lines before reattaching them to the mc and then bleed them so i might try that.
Krazy Texan
1990 v1500 suburban
Old 10-31-2011, 09:24 PM   #10
jocko
jocko's Avatar
ditto on some of the above comments - I did a dual res conversion and added some new lines. Took a LONG time to get the air out - and to even see the first dribble of fluid. I threw my pressure bleeder in the gar-baaaage and borrowed a neighbor. The pressure bleeder spewed crap everywhere no matter what type of seal i applied.
Old 10-31-2011, 09:38 PM   #11
Born Lucky
I have a 64 C20 and at first I tried everything. My last option was a pressure bleeder, this is the only wat you we get a proper bleed, that I built myself.
Parts: pressure sprayer from Ace
pressure guage
hose about 10 ft 1/4 I.D.
air hose attachment ( repair kit style)
I drilled a hole into the sprayer and expoxy the pressure guage
I removed the original sprayer hose and replaced with new hose
I then fabricated a square piece ( I used MDF as it was all I could find) drilled a hole to fit the air hose fitting in the middle. The piece was made large enough to fit over the master cylinder. Then I used a sheet of rubber(same size of the wood piece) to seal the wood between the master cylinder.
To hold the wood piece I used a C-clamp and positioned it to hold the wood over the master cylinder.
I pumped the unit to about 8-10 PSI then started my bleeding process. I also bought about 2 quarts of brake fluid to make sure I got all the air out.
Worked great!! I hope this helps.
Born Lucky is offline   Reply With Quote
Old 10-31-2011, 09:48 PM   #12
blackedoutharley
Did you by chance happen to clamp the single rear flexible brake line while doing the job, to keep fluid from leaking out, and forget to remove the clamp on the line?
Don't laugh, others (not me mind you) have done this before and it is easily overlooked or forgotten.
blackedoutharley is offline   Reply With Quote
Old 10-31-2011, 09:59 PM   #13
krazy_texan
thanks for all the input guys i might try it tommorow if i can though i dont ever remember it taking this long but then again i was much younger and had alot more energy to spare pumping that brake pedal lol
Krazy Texan
1990 v1500 suburban
Old 10-31-2011, 11:22 PM   #14
Crash'd Artwerks
Would you mind telling us a little more about exactly what you replaced ? Did you bench bleed the master cylinder ? Did you do a front disc conversion or just put a new dual reservoir master cylinder on it and keep the drums ? Did you replace ALL of the lines, or just put new ones across the front to do the dual res. conversion ?
I have seen people put the calipers on the wrong side, with the bleeder pointing down, and that traps air in the top of the caliper where the bleeder is supposed to be. You WILL NOT get the air out of the system if this is your problem.
If you didn't bench bleed the M/C, go back to that. We have one of those nifty little bench bleeder kits that has a little plastic clip that holds two clear plastic lines and has some plastic fittings that screw into the ports on the master cylinder. You just put the little clip in between the two reservoirs, and run the clear tubing from the plastic fittings in the ports back up into the reservoir, that way it recycles the fluid, and gets all the air out at the same time. I just used a really big phillips head screw driver to slowly and gently push the piston in and out, watching until all the bubbles stopped coming out.
If you didn't replace ALL of the lines, you could have one of the lines clogged, it could have a kink in the line, or even a split in the line that's causing it to suck air.
Let us know if any of that helps.
-Aaron
Crash'd Artwerks is offline   Reply With Quote
Old 10-31-2011, 11:36 PM   #15
krazy_texan
i put new lines throughout the entire truck with the new mc and i put new hoses and wheel cylinders, new self adjusters, brake pads, and spring kits the only thing on the brakes that i did not replace was the drums themselves.
Krazy Texan
1990 v1500 suburban
Old 10-31-2011, 11:37 PM   #16
krazy_texan
oh and i kept all 4 drums
Krazy Texan
1990 v1500 suburban
Old 11-01-2011, 12:49 AM   #17
blackedoutharley
Fill the master cylinder, pump the pedal numerous times, open all bleeders and check tomorrow for fluid coming from all of them.
Old 11-01-2011, 09:22 AM   #18
Crash'd Artwerks
I didn't see if you replaced them, but what about the actual bleeder itself ? Did you replace all of those as well ?
All but one of mine but one were completely clogged.
Also, I'm sure you did, but I just thought I would try to cover all bases. Did you put the little copper washer on all of the rubber hoses before you screwed them on ?
-Aaron
Old 11-01-2011, 09:33 AM   #19
Crash'd Artwerks
Oh yeah, forgot to mention. When we bled the brakes on my truck, my uncle had a vacuum canister that you hook the air hose to and it has a rubber line on the end of a hose coming out the top the canister that you plug on the bleeder.
It essentially sucks the fluid from the master cylinder to the wheel cylinders. Had my dad at the too filling the M/C and it took no time at all ! Easiest way to bleed brakes, in my opinion. Not messy at all because the fluid gets sucked into the canister.
-Aaron
Old 11-01-2011, 09:13 PM   #20
ol_skool_chevy
ol_skool_chevy's Avatar
Did you happen to replace the rear brake hose? I mean the one before the "T" at the rear end.
I just did my single to duel master and I had a Heck of a time bleeding my brakes only to find out that hose was collapsed. You cant see it from the out side. I replaced mine and BINGO....no problems.
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 11-01-2011, 09:19 PM   #21
lwb66step
lwb66step's Avatar
I didnt see you say you did a bench bleed on your MC....I have always put my MC in a vise and used a long screwdriver to prime it by pushing the plunger in and out repeatedly
1966 LWB Stepside......SOLD
1963 SWB Fleetside.....Current Project
I hate all fords.
lwb66step is offline   Reply With Quote
Old 11-01-2011, 09:32 PM   #22
Crash'd Artwerks
I had the same exact problems so I just went ahead and replaced all three of the rubber hoses.
That's the way I did mine. It's a lot easier and cleaner doing it this way than trying to mess with it bolted to the firewall.
-Aaron
Old 11-01-2011, 10:22 PM   #23
derail
derail's Avatar
Just a suggestion, if you've already bench bled the master cylinder, I would start by disconnecting the brake lines at the master to make sure fluid is coming out there. If so, just work your way down to each fitting in the line and do the same thing. Kind of a pain in the butt, but you want to make sure the fluid is flowing at the starting point. I chased a brake bleeding problem for a long time before I did this and found that a tiny particle of something was plugging the small hole in the master that fed my rear brakes. Like you, a lot of my parts were brand new and replaced all at the same time which made chasing the problem even harder. Good luck.
derail is offline   Reply With Quote
Old 11-05-2011, 05:10 PM   #24
gabe2000
my 2 cent advice: I had trouble with mine because the brake padel push rod was not ajusted correct. So the master cyl.'s push rod was not coming to the back completely. thx
gabe2000 is offline   Reply With Quote
Old 11-06-2011, 08:19 PM   #25
absintheisfun
absintheisfun's Avatar
When I switched to 4 wheel power disc from the stock 4 wheel drum/single master, I had bleeding problems as well. After trying every possible thing in the book, including bleeding about a gallon of fluid through the lines, I stepped back and gave everything another look.
Simple fix:
There was a crap-ton of air in the master, so I couldn't get pressure to build correctly. Once I rebled the master, I rebled the lines and it all worked great!
1967 Camaro - Current Project
1963 C10 - Shop Truck (Next Project)
2008 Saturn Sky Redline - Wife's ride
1993 GMC Typhoon - Getaway truck!
absintheisfun is offline   Reply With Quote
