Cant bleed brakes
ok so i know my truck is a 65 but i am posting here as well as the 60-66 forum simply because this forum sees more traffic but this is where i am at. I just put an entire new brake system on the truck and i literally replaced everything. so i am at a loss here i have exhausted all options possible and yes i have done numerous searches on this forum and on the net and cant come up with a single way to do this i can not for the life of me figure out how to bleed these brakes. I have tried the vacuum pumps i have tried the old fashioned way, and i have tried making the homemade pressure bleeder my problem with it is that i can not get it to seal on top of the master cylinder and i have tried makeing numerous types of caps for it. So please for the life of me someone help me out throw out your options or opinions or what have you cause i am at a loss right now and now that i am trying to park my car for the crappy season i am really needing my truck.
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
Re: Cant bleed brakes
Did you bench bleed the master cylinder before beginning at the wheels?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Just went through this. My mity vac would not pull the air out of the lines to get the fluid to come. I wound up using a childs medicine syringe to fill the lines. Then i had my wife pump the peddle and was done in 15 minutes.
70 CST Bunch of old Camaros ![]() |
where exactly did you fill the lines with the syringe at, did you do it at the bleeder screws?
Well after I spent parts of two days trying to get it to the rear I finally got it to the rear hose. I couldn't get it to pump with the pedal or pull it with the mity vac. I put a piece of vacume hose on the syringe and on the rear bleeder. I opened the other side and about three squirts and it came out the bleeder. The next time I will fill the lines from the front where they come out of the proportion valve. Now they will still be some small pockets of air where you take lines apart to pump it in. But at least then you can move it by pumping the pedal. Then you can bleed them normally.
well i dont have a proportioning valve cause mine is running a non power drum/drum setup but i will fill the lines from where they connect to the master cylinder and then reconnect them and see what happens from there. I figure that it might be a little bit of a lengthy process but sounds like it will work pretty good.
I had a problem bleeding mine one time, must have tried at least 5 times and the pedal still pushed all the way to floor. The problem I had was the rear brake shoes were adjusted to far from drum. Once I tightened them up it worked first time.
Don't know if this will help. Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
i will check that to thanks for the input i think i have run into that once before when bleeding brakes i should have known to do it while the tires where still off the truck
Active Member
![]() Join Date: Jul 2007
Just did my 68 drum drum this summer. I replaced all the shoes and wheel cylinders, spring kits, turned the drums, new master cylinder and the rubber hoses. The hoses is usually a forgotten item but they swell internally and block the fluid to the wheels.
I did the pressure method: 1. Bench bled the master cylinder as per instructions (important) 2. Placed hose on drivers side bleed valve and placed into glass container with a few inches of fluid in it. 3. Had wife help (she hates it) 4. Slowly depress pedal and loosen the bleed valve. 5. Hold the pedal down, close the bleed valve, then release pedal. 6. Repeat until no bubbles in fluid. 7. Repeat on passenger rear, passenger front and drives front. Be aware that new master cylinders may be defective. Internal seals leaking. I've had two brand new I had to return. |
I had a real bear of a time bleeding my girls hydrolic clutch. Nothing seemed to work. I was positive there was an air pocket that just was not moving under normal pedal type bleeding.
I used a turkey injector with a small hose. Installed the hose onto the bleeder valve(it's under the truck near the clutch), opened bleeder valve slightly, and depressed plunger on injector. I did this by myself with no one to help or to depress the clutch pedal. When I depressed the plunger I could hear the bubbles come up and out of the clutch master cylinder. I just did it 2 or 3 times and all was good. I haven't had a problem with her clutch for 3 or 4 months now. The turkey injector holds around 3 or 4 ounces of fluid. You should try it begining with the rear drivers side. It should fill your brake lines with fluid and dispell air out through the master cylinder. Next move onto the rear passenger side the onto the front brakes. My girlfriend and I have litterally spent hours trying to bleed her clutch system only to get marginal results at best. Truck was a 1991 chevy with 5 speed manual. Good luck! Keith |
ya i am going to try something along that line cause if i get under the truck i can hear it trying to pump through the hose but still nothing.
#12 | |
Good luck! Keith |
