Old 10-31-2011, 08:18 PM   #1
J.Cagle
J.Cagle's Avatar
Tips for removing rearend?????
I feel stupid for this, but is there a trick to removing the factory rearend out of my 64? I have everything unbolted but I cannot get it to budge. I thought I could just unbolt the ubolts and track bar and pull it out. The ubolts will not budge. Ive soaked everything with penetrating oil and drove metal wedges between the axle and trailing arm and still wont budge. Any advice? Thanks in advance!!!
1964 c-10 Long stepside, 230 I6 ,3spd, dealer add-on air.
J.Cagle is offline   Reply With Quote
Old 10-31-2011, 08:25 PM   #2
steverino66
Re: Tips for removing rearend?????
I had to cut through the tops of the u-bolts with a sawzall, then twist/break/hammer off the pieces - fair amount of rust had accumulated inside the bolt holes in the trailing arms
steverino66 is offline   Reply With Quote
Old 10-31-2011, 08:45 PM   #3
63sbssbbw
UCA63
63sbssbbw's Avatar
As steve said,just cut the U bolts, you'll be getting new ones anyway.
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 10-31-2011, 09:20 PM   #4
J.Cagle
J.Cagle's Avatar
I would do that but the rear wheels are stuck on. Ive been beating them with a sledge the last hour and they wont budge. Its always somethin!
Old 10-31-2011, 10:05 PM   #5
krazy_texan
krazy_texan's Avatar
i just used an angle grinder to cut mine off then used a big prybar and a 3lb hammer and it came out but it did take some work but while you are under there you might look at your spring mounts as well i wound up having to replace mine as they where almost rotted through
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 10-31-2011, 10:07 PM   #6
rustyrodknocker
zip wheel.
rustyrodknocker is offline   Reply With Quote
Old 10-31-2011, 10:08 PM   #7
J.Cagle
J.Cagle's Avatar
Luckily my truck just has minimal rust in the usual places on the body but everything else is solid.
Old 11-01-2011, 04:57 AM   #8
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
When I took the original rear out of my '62 I just loosened the nuts a little bit then drove it around the block until the u-bolts came loose! I am by no means condoning this. but it did work well since I wasn't able to afford new u-bolts and nits at the time.
Imperial Kustom LLC
Meridian Idaho.
I never stopped playing with cars, they just got bigger.
Imperial Kustom is offline   Reply With Quote
Old 11-01-2011, 05:21 AM   #9
mbgmike
remove the cover and pull the c clips. pull out the whole axle
mbgmike is offline   Reply With Quote
Old 11-02-2011, 10:46 AM   #10
vin63
It's Better With Nitro
vin63's Avatar
At this point, can you unbolt the trailing arms at the forward crossmember and then roll the reared housing and trailing arms out from under the truck as an assembly? This way, you will have more room to work on detaching the U-boilts, etc.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 11-02-2011, 02:24 PM   #11
awbrown
Imperial has the right idea , big torches and hammers if it does not work ...
awbrown is offline   Reply With Quote
Old 11-02-2011, 02:59 PM   #12
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Have you tried heat on the wheels? Maybe just run a torch around the wheel for a minute or so, then give it a smack. Might be enough expansion to bust it loose.
When we took the rearend out of my step-daughters '65, I cut the u-bolts with a grinder, and a sawzall. Make sure you cut them close to the top of the "U". If you don't, you will get to cut them again. That is the voice of experience on that!! Luckily I only did that on one of them.
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 11-02-2011, 08:38 PM   #13
LT1 Burb
LT1 Burb's Avatar
That sucks, I dropped the one out of my truck yesterday in 30 minutes and everything unbolted, even the trailing arm bolts came out.
LT1 Burb is offline   Reply With Quote
Old 11-02-2011, 08:48 PM   #14
pdxhall
pdxhall's Avatar
I'd like to see a picture of this mess. Mine came right out, too. No problems.
pdxhall is offline   Reply With Quote
Old 11-02-2011, 08:50 PM   #15
shawno72
C/10 junkie
shawno72's Avatar
What I did was cut the top of each side of the ubolt right where it starts to curve over the axle leaving just the straight part with the threads. Then just get your impact and start running the bolts tighter and one of two things will happen. Either they will start spinning in place hence braking them free so you can pound them out or as you tighten the bolts they will start to pull through. Piece of cake this way. At least it was for me.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 11-02-2011, 10:43 PM   #16
J.Cagle
J.Cagle's Avatar
Finally got the thing on its way out. It is cray how tight the ubolts can get wedge in there when they get rusty! After prying, hammering and grinding the last couple evenings it is about out.
Another question while Im here haha. Whats the best way to remove the spring purches on the axle thats going in? I dont have a torch or a plasma.......
Old 11-02-2011, 10:56 PM   #17
pdxhall
pdxhall's Avatar
Better take it to someone that does.
Old 11-02-2011, 11:03 PM   #18
J.Cagle
J.Cagle's Avatar
I was afraid youd say that! I dont have a truck bc my 64 is not back together yet lol.
Old 11-03-2011, 05:39 AM   #19
Imperial Kustom
100% gearhead
Getting the perches of with a grinder and cutoff wheel isn't that bad. Just cut along the weld as close as possible to the axle tube. Get through the weld as far as possible while trying not to cut into the tube. Smack 'em with a hammer an grind down the leftover weld. Be sure to take careful measurements of everything so the new perches go back on nice and centered. Then I HIGHLY recommend taking the bare housing to your local race car or Drivetrain shop to have it checked for straight because it will most likely need it. Axle tubes love to move around when you weld to them believe it or not. Axle and bearing failure will result from a warped housing.
Imperial Kustom LLC
Meridian Idaho.
