Old 11-01-2011, 04:16 PM   #1
losthope
losthope's Avatar
Clearencing wheel hole width?
Mainly a question for the guys running bullet push thur-caps with stock wheels, How or what did you use to clearance the hole in the rim so the bullet cap fit between the rim and hub/spindle? Just see what might work the best since i will be tackling this task soon....grinding stone on drill ?...or all else fails have a shop do it.
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 11-01-2011, 05:36 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Clearencing wheel hole width?
curious on this as well.....
Old 11-01-2011, 09:22 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
I had a set of Centerline Smoothies with the same issue. When I was redoing the front end I put the rotor on the spindle and used a flap disc on a grinder and spun the rotor by hand grinding until I clearanced the centercap. I did this because it seemed the easiest DIY way at the time.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 11-01-2011, 09:27 PM   #4
lwb66step
lwb66step's Avatar
i used a plasma cutter to cut the center bore larger to fit late model z71 wheels on my 66 with drums.......i thought about having it milled a a machine shop... especially it you are going for a finished look
1966 LWB Stepside......SOLD
1963 SWB Fleetside.....Current Project
I hate all fords.
lwb66step is offline   Reply With Quote
Old 11-01-2011, 09:50 PM   #5
Mechanic77
I ran into a similar problem with my front center caps on my Street Lites.....I just took the rotors to my machinist friend and had them turned down to fit. Not real diy, and the rear axles would be considerably more work, but you know it's done right
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627
Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948
Mechanic77 is offline   Reply With Quote
Old 11-02-2011, 12:25 AM   #6
jonzcustomshop
1961 crewcab
I have a set of push through bullets for my 59 chevy (car) they fit the axle/hub, and fit the stock wheels, but the holes on my chrome/reverse wheels are too small for the push through... would it be detrimental to the wheel to grind it down 'till the center cap pushes through?
Old 11-02-2011, 08:48 AM   #7
lwb66step
lwb66step's Avatar
I guess it wouldn't change the ride, how much are you going to have to grind down?
I hate all fords.
Old 11-02-2011, 09:53 AM   #8
jonzcustomshop
1961 crewcab
probably 1 to 2 16ths around the circumference... I guess the biggest issue would be grinding through the chrome plate, and opening up a spot for rust....which I guess I could paint the ground area...
Old 11-03-2011, 04:30 PM   #9
losthope
losthope's Avatar
well day one i went to hardware store and picked up the first three items in the picture "Rotary file","grinding drum","half round hand file" it took quite a bit of time and alot of labor , nothing really did a great job but i did get one wheel hole ground to the right size using a combination of all the tools i bought and mounted the wheel, i gave up and said "screw this", then today i decided to go back to the hardware store and see what i could find! I bought some thick cut off wheels for my air die cutter but then thought if i stacked them i could get more done so i picked up a arbor for the drill also, it worked much better and alot faster then the other three items !!!!!!!!!!!!
Timmy D.
Old 11-03-2011, 05:07 PM   #10
samuellg1977
samuellg1977's Avatar
Those caps n rings look awesome!!
samuellg1977 is offline   Reply With Quote
