Old 11-01-2011, 07:36 PM   #1
xxboondockxx
xxboondockxx's Avatar
Header Clearance Help
I have seen and read thoroughly other threads regarding headers and clearance, but still can use some help. I have a 1966 c-20 with 4 gear manual transmission. The engine is a 350 small block. Does anyone else with this setup know which headers will bolt on and clear the clutch linkage? (z bar). Any insight is appreciated. Also any advice or opinions regarding hydraulic clutch. Thanks
xxboondockxx is offline   Reply With Quote
Old 11-02-2011, 12:24 AM   #2
Captainfab
60-66 Nut
Re: Header Clearance Help
The safest bet and easiest to install are the Hedman 69260's as they are made for these trucks. The Hedman 69090 and Hooker 2452's will work, but a little work on the clutch bellcrank and linkage may be necessary.
The '63-'66 trucks can be converted to hydraulic clutch, but it will cost some $$. The kit that I sell, will cost you $213.50, but that does not include the slave cylinder or the line from the master to the slave.
Old 11-03-2011, 11:10 AM   #3
xxboondockxx
Thanks, Captainfab. I will post when install is done.
