11-01-2011, 08:22 PM | #1 |
Need Help with Dodge Steel Rims........
I have done a search on here but not much luck.
I have a set of Dodge 20" steels I want to put on my truck. I have the 73 disc brake set up on my truck now with 5x5 lug pattern. I know some have used aluminum adapters to make it 5x5.5 but I think the added space of the adapter will push the rim out too far. I know others have had the rotors re-drilled. I called Moser and they will do it for $60 plus shipping. I saw a truck at a show the other weekend that had them on and he said he bought chevy rotors that were already in a 5x5.5 pattern but he could not remember where he got them. I have heard some say that you can get rotors in pretty much any bolt pattern so they must be available somewhere?? My question is, does anyone know where I can buy a set of chevy rotors in 5x5.5? To all of you that are running the Dodge wheels, how did you do it??
My build thread: 1966 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=486223 1965 GMC fleet http://67-72chevytrucks.com/vboard/s...d.php?t=651726 |
11-02-2011, 12:21 AM | #2 |
1961 crewcab
Re: Need Help with Dodge Steel Rims........
looked up on boltpattern.net, and the only gm product that showed up with a 5X5.5 is a 98 and up geo tracker....
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
11-02-2011, 04:46 AM | #3 | |
I really wish I knew where to get these as it would be much cheaper then sending them out to get re-drilled. Bump to the top.............
11-02-2011, 05:18 AM | #4 |
I think $60.00 IS a real good price to redrill
11-02-2011, 09:45 AM | #5 |
1965 Chevy C10, 2005 4.8L/4l60
I am not sure but if you want the 6 on 5.5, why not get the CPP spindles that leave the bolt pattern the same and add discs.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-02-2011, 10:19 AM | #6 |
Resistance is Futile
Dodge wheels are 5 on 5.5''.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
11-02-2011, 10:25 AM | #7 | |
11-02-2011, 10:28 AM | #8 |
A couple years ago I talked with someone on the message board using the Dodge steelies. I asked him this question and he replied that he used adaptors and they had helped because the backspacing on these wheels was 6.5''. The deepest wheels I have run on these trucks is 5.5''.
11-02-2011, 01:03 PM | #9 | |
I guess I will order two adaptors and see if they work with the front and the rear before I buy all four. Just wanted to get some advise before I have the rotors drilled. Oh and I called speedway and they do not carry any chevy 5x5.5 rotor........
11-02-2011, 01:09 PM | #10 |
Just found these, looks like it might be what I need..
http://billetwheeladapters.com/5-lug...thick-959.html
11-02-2011, 01:21 PM | #11 |
MOTO, I think you should be good with the adapters and the steelies offset. I ran 20x8.5 with mid 5'' backspace on my burb and had no rub issues with 275/45/20's. The rear axle was a 5-lug 71-72 so a little wider than the earlier set-up. You may be tite on the inside rear but should be able to offset with the adapters.
11-03-2011, 02:08 PM | #12 | |
11-13-2011, 01:42 PM | #13 |
www.loweredd.com
In for results. I have searched and searched trying to find the offset of these wheels. I have a 4 door 79 Impala that needs these wheels. Curious to see if those adaptors work for you.
Posted via Mobile Device |
