Old 11-02-2011, 09:44 AM   #1
bigblok77
What type of a/c is this? orig. aft.?
I found the aluminum trim peice in the floorboard, I was just wandering if it is an original style a/c selector?
this was in the place of the heater selector panel.
thanks guys!
sorry for the little bit of rust...
Wes
1965 chevy c-10 short fleet,http://www.67-72chevytrucks.com/vboa...d.php?t=474572
1999 dodge swb 3.9 DD
2002 chevy 2500 hd 6.0 4x4 (ol' ladys truck)
bigblok77 is offline   Reply With Quote
Old 11-02-2011, 10:32 AM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: What type of a/c is this? orig. aft.?
I think that is the control for the standard heater. I have one in my 'burb and have the plate in my sb'64. I dont know what the large hole was for originally.
I bought a new switch for my 'burb and it works. You pull out the knob to open the heater diverter and you turn the knob to set the fan speed.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 11-02-2011, 10:47 AM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Economy Air Flow heater control, The larger hole possibly for some kind of aftermarket gauge!
Old 11-02-2011, 10:54 AM   #4
kieth
kieth's Avatar
My 66 GMC has that same panel in it with that type of control, but not the large hole as your part has........I have not installed aftermarket A/C heat yet so I use it when the weather gets cold, it works just fine, the change from heat to defrost is done with a manual flapper valve on the heater itself. My truck did not have the deluxe controls. Kieth
kieth is offline   Reply With Quote
Old 11-02-2011, 12:09 PM   #5
T Smith
T Smith's Avatar
Same as my 66 Chevy, as stated above someone drilled that big hole for a gauge.
T Smith is offline   Reply With Quote
Old 11-02-2011, 04:55 PM   #6
bigblok77
Sweet thanks guys, just wasn't sure because it didnt say heat at all... lol
Wes
