'76 c10 gauge cluster swap
Hi all,
Trying to replace my '76 chevy c10 idiot light cluster with what I think is a (73-75) factory tach cluster with gauges (because it has a mechanical oil pressure gauge and ammeter, not volts). The FAQs cover the pre-73s, but not these. This is asking a lot, so I will not be surprised if I get no responses. The principal is straightforward - rearrange the cluster plug pins to support the new cluster but it's not a clean swap. Any light shed on the following would be very much appreciated: 1. The ammeter gauge in the "new" plug calls for 2 pins (wires) - a black wire (ground?) and a black and white wire - that the old harness does not have. 2. What do I do with the orange generator/ignition wire and the brown generator wire, both of which are not included in the new gauge cluster? Do they now go to the ammeter or removed? Thanks for anything, however trivial. Peter |
Re: '76 c10 gauge cluster swap
Ok, how 'bout this: anybody have a schematic or wiring diagram that shows the gauge cluster pin positions for a '75 c10 with gauges and tach?
(the FAQ info has info for lights and gauges w/o tach, but not gauges WITH tach) Thank you! Peter |
#3 | |
Getting Old; Going Broke
http://www.73-87.com/7387garage/inte...achometers.htm
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
You cannot use an amp cluster with anything but a 73-75 unless you plan on some major rewiring.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
My truck is a 76 with mech oil and volt gauge. I bought a tach cluster and the guy said it was from 76 and it too has mech oil gauge and volt meter.
Is this a plug-n-play since both have mech oil and volts? Will my gas gauge work in new location? I just dont want to burn anything up LOL
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
