Old 11-02-2011, 04:56 PM   #1
lifted k10
86 c10 rearend ?
Hey guys I have a 86 c10 gmc step side 4.3 4 speed with granny first gear. My qestion is what gears do I have in the rearend and will my current bell housing fit a 350 engine?
lifted k10 is offline   Reply With Quote
Old 11-02-2011, 05:14 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 86 c10 rearend ?
No way of knowing the gear ratio short of checking it personally. You'll have to either jack it up and spin the wheels or remove the cover and see the gear tooth count.
Bellhousing fits a small block fine with no mods.
Old 11-02-2011, 05:37 PM   #3
lifted k10
What about the flywheel will it fit on a 350 too?
Old 11-02-2011, 06:48 PM   #4
406 Q-ship
406 Q-ship's Avatar
The bellhousing from the 4.3 will bolt to any SBC, the flywheel should be from the later one piece rear main seal design. I am not sure if the balance on the 4.3 in 1986 and later is the same as the 350 after 1986. The flywheel will not fit any 1985 or earlier two piece rear main seal SBC, bolt pattern is different.
PS 400 SBC will not interchange with the 4.3 flywheel under any case.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 11-09-2011, 01:25 PM   #5
Slonaker
Insert Witty Text Here
Slonaker's Avatar
My '86 Chevy lists the gears on the tag in the glovebox. Maybe yours does as well?
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 11-10-2011, 08:20 AM   #6
Keith Seymore
Keith Seymore's Avatar
Slonaker
In my experience the SPID lists optional gears, along with the RPO, but not the base (std) gear ratio.
According to the powertrain charts listed in the GM Heritage Center info packet (http://www.gmheritagecenter.com/gm-h...olet-Truck.pdf - page 19) it depends on the GVW. There is a base axle as 3.08 (4900/5200 lbs gvw), 3.42 (5600 gvw) or 3.73 (6100 gvw). That's assuming that they've never been changed.
Like TXFirefighter says: no way of knowing without checkin' em out.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-10-2011, 09:29 AM   #7
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
My 85 with the 4.3 and 4 speed has 2.73 gears.... Not for long though...
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 11-10-2011, 01:45 PM   #8
Keith Seymore
My bad - you are correct. There is an entry for a 2.73 base gearset (page 20). I was accidentally looking at the wrong chart (for California emissions).
K
1979-1986
1986 - 2019
Old 11-10-2011, 02:44 PM   #9
Keith Seymore
Here's a copy of the actual powertrain chart, so that we are all on the same page:
1979-1986
1986 - 2019
