![]() Join Date: Mar 2011
Door panels interchangable?
I was wondering if the '72 door panels would fit on a '71 without modding it? I like the look of the '72 better. Anyone try this before?
Gary '71 3/4 ton ![]() I know just enough to get me in trouble |
Petroleum User
Re: Door panels interchangable?
Thats a stumper for me, I never had a '72. I think they all fit each other, though. I know the '67-'71's are interchangable. My faves are the '67-'68's.
![]() 1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
Roadtrip!
![]() Join Date: Feb 2003
You will need to have 72 regulators to go with 72 panels. 72 panels also mount differently, but can still be made to work fairly easy.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
i dont see why they wouldnt....i put the older metal panels in my 72 because imo, they are much cleaner..swapped right over.
SWB 4x4 Collector
![]() Join Date: Jun 2001
As Eric stated, the 72 regulators are longer shanked. The reason 67-71 door panels work on 72' doors is that the shanks are longer, though there will be an bigger gap between the panels and cranks. A 72 door panel will be too big for the earlier regulator shanks without using strong force and damaging the plastic of the panel or the applique if Cheyenne Panels. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
ok sounds good then, I had planned on replacing those anyways. Thanks for the info guys
You will also have to do some work on the screw holes
the 71 and older screw on and the 72 use the plastic snaps if you pop out the nut holders on a 71 or older door for the plastic 72 door holders the holes are just a little to big to hold the retainers tightly
can we have a pic of a 67-71 door next too a 72 door
1965 c10 short stepside ![]() 1967 c10 fleetside 350/350 trans (my baby) |
