Old 11-02-2011, 09:39 PM   #1
benoit454
Chris
benoit454's Avatar
88 messed up again.
yep out of nowhere, was running fine, my dad went to take it out tonight, started and shut off imediately, then did the same, now just cranks. My battery light is on, not sure if it was before or not, no codes, fuel pump you can hear but nothing from the injectors. I had this happen before and it started working on it's own. Last time I had this issue I checked for fuel to the tbi and it got it good, and shot it from behind the fuel filter when the filter was removed, turned it on shot out th eline about 3 feet.
Seems to be doing the same thing, haven't checked yet, I could probably dump gas in it and it fire up, but won't stay running.
I have to check it out, any ideas? I'm gonna check for spark and fuel and check the FP fuse and such, but would a relay do this? work then stop, then work, and stop again out of the blue?
Chris
GIT R DONE!!!!!!
Check out all our rides,
