holley 500
I found a holley 500 #4412 on craigslist for $150. Is there something I should check for before I buy it? The guy said it was like new about 25 hours on it. Still has the choke hardware on it. He said it was used on an industrial truck. I know these are $300 carbs so the price is good. Oh yeah I'm putting it on my V6 305. Thanks
#2 | |
Re: holley 500
![]() Join Date: Feb 2011
Re: holley 500
I put one on my V6 as well. Ebay item I believe; around $125 a few years back I believe. It was a barely used Circle track Carb. I went off the Sellers rating and pics of the carb. Sorry, I know that doesn't answer your question directly, but mine just bolted on and worked great! You should be quite happy with the results.
MusicMan70 1961 GMC Suburban |
Re: holley 500
If it were me, I`d just put it on and try it out, the most it could need would be gaskets which you`ll find out right away...if it needs it.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
![]() Join Date: May 2007
Re: holley 500
Does the add have pics of the carb ? if it looks ok it should be ok unless he was running salt water in it.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Re: holley 500
Well I'm picking it up tonight so will post pics tomorrow.
Re: holley 500
Here it is, It's a little dirty. Also the adapter, don't have threads to bolt down the carb. You have to bolt it down with bolt and nuts. Did I get the right one?
Re: holley 500
That appears to be correct and looks pretty clean. The adapter should have all the bolts you'll need to attach the adapter to a GMC two barrel manifold and the studs to place the Holley as well. You will have to to "hog out" the GMC intake to match the plenum areas.
You may have seen this link already from Jolly's 6066 GMC site.... http://www.6066gmcguy.org/holley.htm
Re: holley 500
What do you mean by "HOG OUT" the intake. I thought it was an easy bolt on task.
Re: holley 500
When you place the adapter on the factory GMC two barrel intake, you will see that the opening on the adapter is larger than the GMC opening. You will need to "port-match" the two. I traced the inside difference with a marker and grounded out the opening to match. The "hogging" term I picked up from another site, but I believe this was the intented meaning.
Re: holley 500
Ok I installed the carb and had to adjust a little but runs fine, but when I was revving the engine I noticed that it was leaking tranny fluid from the front of the tranny. So I guess if its not one thing, its another.
