Old 11-02-2011, 10:16 PM   #1
Jon Scully
IRON DUKE chanes head gasket now runs very rough
ADVICE / ACTION PLAN wanted:
The story:
Bought a nice 1986 s10 2.5 Iron duke 2wd tbi; Ran great but had a broken head bolt-- Got a great deal, took it home and took off the head, checked for true-- seemed good with my straight edge removed the broken bolt from block, cleaned the head, cleaned cylinder block, re-installed head, torqued all rockers to factory spec ...20ish cannot remmeber exact at moment. Put new fuel filter, plugs, wires, cap, rotor.
Hooked up all the wires and vacum lines...no left over parts.....start her up...
AND it ran, but very rough.....Like it was on two cylinders or the timming was way out.....shaking ... low idle.....only ran it for a minute max- and decided to take a breather.
I have done this sort of thing before with no issues.....so need a nights rest, some thought, and some of all of your advice....
What to do?
Jon Scully is offline   Reply With Quote
Old 11-02-2011, 10:17 PM   #2
Jon Scully
Re: IRON DUKE chanes head gasket now runs very rough
sorry for the typo in the title lol
Old 11-02-2011, 10:21 PM   #3
truckdude239
truckdude239's Avatar
you valves are 2 tight there is no torque spec for the valves i'll see if i can find the propers adjustment for them ina few
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-02-2011, 10:33 PM   #4
Jon Scully
Maybe....but the manual said to torque for my year engine-- there is no adjusting nut like i've seen on other motors-- just the bolt/ rounder washer that holds the rocker down.....
BUT...If that was the case-- how much damage could have happened....bent push rods or worse?
thanks for the check tho--I will double check too,
jon
Old 11-03-2011, 05:07 AM   #5
lurch115
lurch115's Avatar
it could be possible that the computer was reset and is "relearning" the settings. that and are you certain the MAP sensor is hooked up to the correct spot?
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 11-03-2011, 09:38 AM   #6
Jon Scully
Thanks for MAP question, I will check again to be sure: Keep the suggestions coming, I am building a list that I can go over.....when I get back to it.
To check for MAP operation...I will look into how to see if the MAP is good.
Again: I had no running issue prior to head gasket change....ran great, started with high idle, then idled down.....
Old 11-03-2011, 10:15 AM   #7
truckdude239
http://www.hotrodders.com/forum/valv...5-a-23075.html CHECK THIS OUT
David fuller
2000 Tahoe 5.3l 378
Old 11-03-2011, 11:26 AM   #8
Jon Scully
Originally Posted by truckdude239 View Post
Thanks! I had read this last night-- from my manual/etc I think I set it properly. But I will check tomorrow. The one mistake I may have made: I did not realize that each cylinder had to be set to TDC to torque the bolts down for its' rockers. I hope I did not screw up the cam. A stated before, I only let her run a few seconds per shot (3 times).
I will get the valve cover off tomorrow, and have a look see--
All of you advice is welcome-- This board is such a wealth of knowledge. I used to work in a forklift shop; but have since changed career paths...so It is great to have a place to come and chat about these things!!!
151, 2.5, head gasget, iron duke, roough idle
