Old 11-02-2011, 11:00 PM   #1
CHEVYHD496
CHEVYHD496's Avatar
402 swap questions
i have a 71 c10 with a sbc in it, and i will be putting a 402BB in soon. i want to reuse my TH400 but can i reuse the torque converter for the BB? also what mounts and pulleys will i need? i dont have a/c. anything else i need to know to swap to a BB?
thanks all
71' C10 2wd. 350/400 putting in a 496/700R4
72' C20 2wd 402/400 Cheyenne Super
02' 2500HD EC/LB 4x4 496/Allison- MODDED
USMC 06-14 / 0331
OIF VET
CHEVYHD496 is offline   Reply With Quote
Old 11-03-2011, 12:11 AM   #2
Livrat
Member #1049
Livrat's Avatar
Re: 402 swap questions
Yes you can use the same torque converter and flywheel, you will need all the corresponding BB pulleys, alternator and power steering brackets with pump/hoses, engine towers, fan shroud etc.
Livrat is offline   Reply With Quote
Old 11-03-2011, 12:40 PM   #3
CHEVYHD496
CHEVYHD496's Avatar
can i use my sbc frame mounts to mount my BB? and whats the difference between 68-71 and 72 BB mounts? anyone use performance onlines tubular engine mounts?
USMC 06-14 / 0331
OIF VET
Old 11-03-2011, 03:11 PM   #4
RenoKeene
Florida Edition
RenoKeene's Avatar
You'll need BB mounts and lots of other goodies. Check out the parts for sale section.
Welcome to the forum!
Here's a pic of my 402 for inspiration..
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 11-03-2011, 07:58 PM   #5
CHEVYHD496
CHEVYHD496's Avatar
looks good! what other goodies do i need?
USMC 06-14 / 0331
OIF VET
Old 11-03-2011, 08:31 PM   #6
RenoKeene
Florida Edition
RenoKeene's Avatar
You'll need a BB power steering pump with remote resevoir and the pressure and return lines, also a 4 row radiator and shroud. Probably a 7 blade fan and spacer. If your serious start making a list and saving your $$. Check the parts forum for prices, with the parts we've already listed you're already looking at $500+
Old 11-03-2011, 08:45 PM   #7
RenoKeene
Florida Edition
RenoKeene's Avatar
Oh yea, if your running AC, brackets are another $200.
It takes commitment to go big...but there is nothing like the roar of a big block under the hood!
Old 11-04-2011, 02:20 AM   #8
VA72C10
VA72C10
VA72C10's Avatar
I'd say 500+++ Almost worth looking for a truck with the 402 in it and then part out or sell the truck w/out the engine in it....
Prices w/out shipping (what I've paid and seen them sell for)
71 BB Mounts 100-150
71 BB mount rubber 100-150
Or do the small block mount modification 50-100
PS setup (lines, reservoir, pump)200-250
Fan shroud 100-150
Clutch fan 50-75
4 core radiator 200-250
4 core brackets upper and lower 50-100
Pulleys 150-200
alt brackets 75-100
bb exhaust manifolds 200-250 (or headers)
bb heat shield for firewall 50
That's 1275 on the low end for the parts (1725 on the high end)....if you can find a setup for 500 I'd JUMP on that deal!
I just sold a set of restored 72 big block brackets, pulleys, and the ps setup for 975 locally....what I paid for them when I got them...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-04-2011, 12:26 PM   #9
RenoKeene
Florida Edition
RenoKeene's Avatar
Fan shroud 100-150
Clutch fan 50-75
Pulleys 150-200
alt brackets 75-100
Yea, I didn't want to give him a heartattack
Old 11-04-2011, 01:48 PM   #10
69sixpackbee
You don't need those high-dollar AC pump brackets. I used a Sanden pump on mine and I went with the brackets that came with the retrofit kit. A lot cheaper.
Bud
69sixpackbee is offline   Reply With Quote
Old 11-04-2011, 01:24 AM   #11
CHEVYHD496
CHEVYHD496's Avatar
thanks for the info! im hoping to cut that price down alittle! ecspecially since im not running a/c
USMC 06-14 / 0331
OIF VET
Old 11-04-2011, 10:49 AM   #12
sboris
sboris's Avatar
I have a couple things left i can make you a deal on, would get you started. Of course as va7210 stated a whole setup would be easier. Heres my thread.
IA Extra BB parts/4spd humpnboot misc ( 1 2)
sboris
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
