Old 11-03-2011, 03:57 AM   #1
72c10lover16
72c10lover16's Avatar
How do you correct the speedometer for larger tires?
I have a 68 chevy pickup with a 4 speed in it. it is a 4 wheel drive pickup. i have 33 inch tires on it and i was wondering how do you correct the speedometer for the larger tires?
68 swb 4x4 327 4 speed
72c10lover16 is offline   Reply With Quote
Old 11-03-2011, 09:24 PM   #2
webfoot
Re: How do you correct the speedometer for larger tires?
The speedo gear in the transfer case will have to be changed out. Not sure of a source though. If it is too far off you will also need to get a different drive gear. There are 2 parts; drive gear on the output shaft and the driven gear which is where the cable attaches to.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 11-03-2011, 09:44 PM   #3
72c10lover16
Does anybody know what spedo gear I would need. My speed is off by about ten doing interstate speed
Old 11-03-2011, 10:01 PM   #4
webfoot
10% or 10 mph? Need to drive by a radar point and note the difference, otherwise you'll just be guessing.
-me
Old 11-03-2011, 10:09 PM   #5
72c10lover16
I'm not guessing. DOing 65 on the spedo is really 75
Old 11-04-2011, 05:38 AM   #6
Todersauce
I use an old GPS most have a speed display its not fast to respond in traffic but they work well on the highway and its cheaper then a big bill from the trans shop.
Todersauce is offline   Reply With Quote
Old 11-04-2011, 03:00 PM   #7
OrrieG
OrrieG's Avatar
This might help:
http://www.chevytalk.org/fusionbb/sh...hp?tid/256975/
OrrieG is offline   Reply With Quote
Old 11-30-2011, 02:12 AM   #8
rayfinseats
Try a local chevy dealer parts counter. They usually can tell you.
rayfinseats is offline   Reply With Quote
Old 11-30-2011, 09:07 AM   #9
33s don't even throw my speedo off enough to matter. My experience with 37s has been it's off about 10%. I've had several vehicles with both. You must have the wrong gear for your ratio even with stock tires or something's wrong with your speedo. The worst I've seen was running 37s on 3/4t trucks that would have 31s originally. Which was 10%,like 70 read around 63 or 55 reads 50.
On my '85 Jimmy that came with 3.07s and short little 235/75-15s that I now have 4.10s and 35s with nothing changed with the speedo it reads about right up to about 50,then shoots up to 75-80. I haven't figured that one out yet,but figure it's something in my speedo.
Old 12-01-2011, 02:06 PM   #10
coondogg52
I am running on 33" tires and my speedo is off 5 mph when at freeway speed, but as I go slower the speedo tends to get closer to true.
coondogg52 is offline   Reply With Quote
Old 12-02-2011, 05:09 AM   #11
skoffice
skoffice's Avatar
I have the exact same problem with my 33's. Here locally there is Sacramento Speedo that I need to look into visiting very soon. I think there is a larger source for parts in Nevada as well. I believe Nevada Speedometer is the name of company. Very original business names
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Old 12-03-2011, 07:26 AM   #12
^ What city is Sacramento Speedo located in?
Old 12-12-2011, 11:13 AM   #13
thirdstreettito
Resident of Here
thirdstreettito's Avatar
My 88 has 31's on it. Factory was 235/75R15(28"). When it says 55mph I am really doing 60mph. I got it checked at a local shop that has the rollers.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-12-2011, 11:47 PM   #14
Gene
Gene's Avatar
I'm running 35's and mine is off 9mph.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
