Old 04-17-2003, 12:42 PM   #1
TIMSPEED
TIMSPEED's Avatar
Question about cutting coil springs...How much?
I just want literally 3/4" of drop. Few Questions:
1.) Would that 3/4" drop make me get realigned/new shocks?
2.) How much of the coil should I cut off? (I'm not heating them, I'm going to cut them with a saw.)
3.) Will that 3/4" make my ride BOUNCE? (Cuz I know after you cut your springs, your shiz bounces like a MOFO, but I think that might only be when you cut them SHORT!)
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 04-17-2003, 12:46 PM   #2
Low87
been here longer than Liz
Low87's Avatar
3/4" won't affect your shocks. I wouldn't cut coil springs at all, but if I had to it wouldn't be more than one coil. That shouldn't give you the potato wagon effect.
New drop coils are less than $100, especially for a 1" drop (will 0.25" more make you mad?). Why don't you just go with those and save suspension integrity and ride comfort?
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 04-17-2003, 12:56 PM   #3
TIMSPEED
TIMSPEED's Avatar
Actually, I think that solid 1" would make my tires rub. Cuz the passenger side is right at 29½"...which means, it would be at 28½" after my drop, which means I would prolly rub if I hit bumps (I have 28" tires)
See Them Here
Old 04-17-2003, 01:06 PM   #4
Low87
Low87's Avatar
1/2" or 3/4" clearance, either way you're going to rub. I've got almost 2" clearance and mine rub.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 04-17-2003, 01:13 PM   #5
TIMSPEED
TIMSPEED's Avatar
Hmm...maybe one solid inch wouldn't rub...but maybe they're supposed to be like that so they WON"T rub. I imagine when I hit bumps, they're going to bounce up...so maybe I'll just leave em...
See Them Here
Old 04-17-2003, 01:16 PM   #6
Low87
Low87's Avatar
Give your truck more than a week to settle also.
Be patient young grasshoppa'
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 04-17-2003, 01:22 PM   #7
TIMSPEED
TIMSPEED's Avatar
I'm hearing mixed stuff on that...some say it's not gonna settle much more, but some say it'll settle about a ½"...we'll see after a month of me driving it...soon...
See Them Here
Old 04-17-2003, 03:34 PM   #8
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
dONT CUT EM!!
I have seen springs take a month or more to settle.
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 04-17-2003, 04:04 PM   #9
TIMSPEED
TIMSPEED's Avatar
That's what I wanna hear!
See Them Here
Old 04-17-2003, 04:06 PM   #10
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Question about cutting coil springs...How much?
I won't say yes or no, but I will say if you modify the suspension it should be checked.
This isn't an easy question as you are going to have to "experiment" with the spring. IE, you need to cut it stick it back in, drive it. Plus you need to make sure you set it correctly/the same each time. Cut from the top and start about 1/2" from the end at a time (doing both side). put it back in, drive it, measure. Continue until you get close enough and stop. Remember, if you screw up and cut too much you can put it back on.....
You would be incorrect about that, cutting a spring makes it stiffer. You are reducing the effective coils and increasing the wheel rate. Racers did this stiffen up the car. Incorrect shock application (too long a travel with to short a distance) are what cause a bouncy ride because there is no dampener (shock) to stop all the oscillations. I can't tell you the number of springs I have cut. What do ya think they did before they started making drop springs? Ya cut 'em. Of course, since they started making drop springs, I haven't cut any. BTW, I wouldn't attempt more than about 1.5" out of cutting a coil spring.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
