11-03-2011, 10:55 AM | #1 |
04' silver. 4.8 swap for 5.3
I'm not totally satisfied w my 4.8 in power and towing my bike trailor w going to the beach, thought of having a 5.3 put in. What all would be involved in this swap? Would it be as easy as when we used to swap out the old 305 for a beefy 350????
Just wondering before I try this myself! Thanks......
Things happen for a reason! |
11-03-2011, 01:14 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: 04' silver. 4.8 swap for 5.3
would be just like that, except you would need to reprogram your PCM, piece of cake.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-03-2011, 02:43 PM | #3 |
Has more rust than truck...
You can go 5.3 or 6.0 with just a tune. Or PM member Shon and try a custom computer tune with your 4.8, I think you'll be surprised.
11-03-2011, 03:07 PM | #4 |
The bore and stroke is different on a 4.8 and a 5.3 isnt it? I would think so!
11-03-2011, 05:15 PM | #5 |
cam & tune tha 4.8....
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
11-03-2011, 06:48 PM | #6 |
5.3L & 4.8L share the same bore, The 4.8 has a shorter stroke. The factory tune in your PCM will run a 5.3L NO problem.
11-03-2011, 08:20 PM | #7 |
usmcchevy guy says that I can tune my 4.8 to run like a 5.3 atleast that's what I gathered from his reply above. So if that the truth then why change motor's? What kind of program needs to be added or what??? I'm clueless to this pcm crap!!!
11-03-2011, 09:09 PM | #8 |
i'm not sure that is what he implied... i think he is saying you can swap out the 4.8, and then put in the 5.3 without having to change the computer.
1968 Chevy C10 swb fleetside 2005 Chevy Silverado crew cab (SS) 1977 Goldwing cafe racer 1977 Chevy nova (first car/ first love) |
11-03-2011, 09:10 PM | #9 | |
I was just pointing out a stock 5.3L will run just as good with the stock 4.8L tune as it does with a stock 5.3L tune in the PCM. I have swaped several 4.8s for 5.3s for towing purposes & the 5.3 always outperfomes the 4.8 |
11-03-2011, 09:13 PM | #10 | |
Give this place a call for more info on the computer tune, he is a vendor here. https://www.herronperformance.com/st...&productId=260 |
11-04-2011, 08:05 AM | #11 | |
11-04-2011, 03:25 PM | #12 |
The 5.3L is nothing more than a stroked 4.8L. I have a 4.8 in my 02 1500 4x4 with a few bolt ons and it will keep up with the slightly modified 5.3 in my Tahoe. Swap in a LQ9 6.0L cam and a good tune and you would net roughly 330hp or more with the 4.8. its cheaper than a swap and tune. there is a guy on ebay selling genuine gm LQ9 camshafts for $69.
