Old 11-03-2011, 02:00 PM   #1
Dustin07
Stirrer of the Pot
body drop 60-66
any pictures of bodydrop progress? I've only seen maybe one thread ever and it didn't have many pics of BD'd 60-66 progress.
seems like one guy had just lowered the cab mounts a bit then notched the tunnel? wondering how far that will take you and would love to see builds of other peoples body drops.
Dustin07 is offline   Reply With Quote
Old 11-03-2011, 03:36 PM   #2
Allensracing
Allensracing's Avatar
Re: body drop 60-66
there is about one inch of clearance between the frame and the cab. (maybe a bit more). I have dropped the cab right to the frame, but it isnt much of a drop. if you want more of a drop you need the really cut up the cab to drop it around the frame.
Allensracing is offline   Reply With Quote
Old 11-03-2011, 06:59 PM   #3
csa daddy
csa daddy's Avatar
Re: body drop 60-66
or stock floor body drop it
csa daddy is offline   Reply With Quote
Old 11-04-2011, 01:18 AM   #4
64shortc10
64shortc10's Avatar
Re: body drop 60-66
I lowered my body mounts 3/4 of an inch. Also bought parts and pieces of Porterbuilt Streetrods bolt on body drop and my pinch weld now holds my frame off of the ground by a 1/4 to 3/8 of an inch. When I remove the pinch weld it will lay rocker! Check out my build thread $500 bucket.
Tony from Norcal
64shortc10 is offline   Reply With Quote
