Old 11-03-2011, 04:07 PM   #1
banno
banno's Avatar
Common tire size in the seventies
Hello all,
I need your help: I don't want to use on my 1965 C10 the original wheels with the 6.70 tires. No problem in the USA, but in Germany it is no longer street legal to install bigger tires than the original, on a classic car (max. 2 size bigger are allowed).
Sole exception: If I could demonstrate, that it was a common practice to install bigger wheels (within the first 10 years after the initial registration), then the German technical inspection agency (TÜV) will turn a blind eye.
So, now my question: Has anybody old magazines, brochures, parts catalogs or pictures of the early seventies that could help me?
My goal is to legalize minimum 235 (better 255) tires on 8x15 rims.
Thanks in advance
Greetings from Germany
banno is offline   Reply With Quote
Old 11-03-2011, 04:26 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Common tire size in the seventies
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 11-03-2011, 04:49 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
common ones were G70-15
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-03-2011, 05:21 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Your truck could have been optioned with a taller tire and rim from the factory. You could use any larger wheel and tire till 1975 then? The 74 Chevrolet Blazer had a 15"x8" standard steel wheel available from the factory that looks identical to your stock 5" steel wheel. You could option the truck originally with up to a 7.00 x 17.5" tire
Tire articles from Coker Tire
http://store.cokertire.com/firestone-bias-ply-tires
http://store.cokertire.com/15-inch-t...?adjclear=true
http://clubs.hemmings.com/clubsites/...conversion.htm
http://www.performanceplustire.com/t...of-plus-sizing
http://www.planethoustonamx.com/main...sion_chart.htm
Old 11-04-2011, 03:05 PM   #5
banno
banno's Avatar
The 8x15 rims would be Ok. Do you have such a list for trucks until 1975? Which tire size had the Blazer in 1974/1975?
At the moment my C10 is fitted with 245/60/15 on 8x15" rallyes in the front and 295/50/15 on 10x15" in the rear. It looks really brute. Everybody likes it, but not the guys from the technical inspection agency
Best regards
Banno
Old 11-04-2011, 03:10 PM   #6
aerotruk63
aerotruk63's Avatar
Can you switch wheels and tires for inspection then switch back?
Old 11-04-2011, 03:28 PM   #7
aerotruk63
aerotruk63's Avatar
Old 11-04-2011, 03:51 PM   #8
aerotruk63
aerotruk63's Avatar
I posted in the 67-72 section as well!
Old 11-04-2011, 04:35 PM   #9
banno
banno's Avatar
It seems, that the maximum tire size on 15"" rims was G78x15 or 8.15x15. Converted: 225/75/15.
Hmm, still a little bit skinny.
In worst-case I assemble this wheels for the inspection day, and later the old ones back.
Problem is, that the allowed tire size is written in the German vehicle registration document. The next police stop could be a problem.
Well, no risk no fun
Old 11-04-2011, 04:38 PM   #10
aerotruk63
aerotruk63's Avatar
Their tough on you!
Old 11-05-2011, 02:36 PM   #11
ol_skool_chevy
ol_skool_chevy's Avatar
Move to America..................I will Give you big tires just so you can have what you want.....that's a crazy law
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 11-06-2011, 11:58 AM   #12
banno
banno's Avatar
Yes, the germans are really crazy. Skinny tires is mandatory. To drive with it 200 mph on the Highway is allowed....
