Old 11-03-2011, 04:09 PM   #1
4 eyed Apache
4 eyed Apache's Avatar
1959 hand E brake
I am intalling my e brake cables but am unsure if it is a rod or a short cable that attaches to the hand lever. Can anyone please show me pictures of 55-59 hand brake under dash. Thanks
4 eyed Apache is offline   Reply With Quote
Old 11-03-2011, 04:30 PM   #2
Maximus
Maximus's Avatar
Re: 1959 hand E brake
I don't have photos but when I tore my truck apart for my subframe swap I specifically remember removing the metal ROD that attaches to the hand lever. It bolts to a fulcrum bracket on the frame that goes back to the e-brake cable bracket under the cab.
Is your frame stock? If it has been modified (like so many of our frames have been) the bracket that the rod goes to will be long gone.
but to answer your question, its a rod.
Maximus is offline   Reply With Quote
Old 11-03-2011, 05:14 PM   #3
OrrieG
OrrieG's Avatar
I don't have a photo but here is a sketch I did for another member.
OrrieG is offline   Reply With Quote
Old 11-03-2011, 07:20 PM   #4
4 eyed Apache
Thanks that helps. It was as if I were looking at a real picture! lol
But really thanks!
Old 11-03-2011, 07:21 PM   #5
4 eyed Apache
Thanks!
Old 11-03-2011, 07:39 PM   #6
Russell Ashley
Russell Ashley's Avatar
This is a pic of mine when I got it.
Russell Ashley is offline   Reply With Quote
Old 11-03-2011, 07:41 PM   #7
4 eyed Apache
Thanks that really helps alot to see it!
Old 11-27-2011, 01:57 AM   #8
Green 1959
Green 1959's Avatar
You should do a built thread for your truck. Its cool seeing others like me on here!
I pity the fool with only 2 headlights!
Green 1959 is offline   Reply With Quote
Old 11-29-2011, 12:39 PM   #9
robnolimit
robnolimit's Avatar
If you swap to an IFS or clip, you loose the the lower rocker bracket. (A-Arm in it's place) We have a cable kit that connects from the O.E. brake handle, down to the O.E. lever on the chassis to solve this problem.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 11-29-2011, 02:43 PM   #10
Green 1959
Green 1959's Avatar
I'm trying to set up a floor e brake. I just need to find a place to make a cbale to the length I need
Old 11-29-2011, 11:30 PM   #11
robnolimit
robnolimit's Avatar
look up "Control Cables" - google, they will build you anything you need, - very helpfull.
Old 11-30-2011, 07:20 PM   #12
Green 1959
Green 1959's Avatar
Thank you, I will
