74 2WD C20 Body swap onto 87 K20 4x4 frame and running gear?
To make a long story short I've found a 1987 GMC 2500 4x4 for a very decent price... The truck is complete 350/400 NP208. I want to swap the cab and core support from of my 74 C20 (2WD) onto the 87 frame and running gear.
I know I'll have to modify the front portion of the 87 frame to fit the 74 core support, and remove the 2WD tranny hump... I was just wondering if there would be any other foreseeable porblems? I read somewhere that I might run into clearance problems trying to fit the NP208 under the 74 cab... Can anyone confirm this? I'm sure a small body lift would help? Cheers!
YOUR MONEY'S WORTH. MILE AFTER MILE AFTER MILE. ![]() |
Re: 74 2WD C20 Body swap onto 87 K20 4x4 frame and running gear?
I dont know about the 4wd stuff but the cab will bolt to frame mounts you just have to use 81-87 cab bushings. The frame brackets for the core support only need to be moved about 3/4in.
John 82 Chevy Silverado 350ci/TH350 ![]() |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
I have never moved the core support mounts on the ones I have swapped.
If you don't use a body lift, you will need the trans tunnel from the original as the 2WD hump won't work. Is the 87 cab that bad?
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Thanks for the info! Every bit of advice helps. I'm sure it's going to be fairly straightforward. I was basically curious whether someone has done a similar swap . Good to know I can get away with just moving the factory rad support brackets a touch.
#5 | |
Thought it would be neat to swap the 74 body onto a platform with slightly more modern components. I thought about modifying the frame on my C20 and putting in longer/larger springs front and rear, shackle reversal etc. etc. I paid very little for the 87. I would have spent much more time and money trying to modify the frame on my C20.
