Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 11-03-2011, 07:39 PM   #1
marc54
Solved: Aux input for my stock radio!
I really wanted to keep the stock look of my dash, and dont like the placement of an aftermarket radio. And all I wanted extra was to be able play my Ipod thru the stock radio. Didn't like the available options nor even knew if they would work on my old radio. So I got out my breadboard...
I took out the tape deck and unplugged the whole harness. The wire diagram is stamped on the case of the control module. The ones we're after are,
2- L Audio
3- R Audio
4- Audio Common (ground)
5- 12v
6- Tape on (signal that tells the radio that a tape is playing)
So you're going to solder in an 1/8 inch stereo jack on the 3 audio wires and a spst toggle switch between 5 and 6. In normal tape playing, T-ON is a 5vdc logic level but the control unit appears to be only looking for a signal on that wire so the 12v works.
Easy as that. (do this at your own risk...)
I took everything out of the tape deck and lined it with fabric and put the shell back in the dash.
marc54 is offline   Reply With Quote
Old 11-03-2011, 09:37 PM   #2
89chevsj
error 404
89chevsj's Avatar
Re: Solved: Aux input for my stock radio!
well done!
89 Chevy swb 350 "SJ" DD turned parts truck. SOLD
90 Chevy ext cab loooongbed. "storm trooper" Rust In Peace.
06 Kia sorento wife's car
06 charger srt8 "lucifer" my toy
'12 Kia optima
89chevsj is offline   Reply With Quote
Old 11-03-2011, 10:20 PM   #3
bpeters5814
bpeters5814's Avatar
That is awesome. Looks really good.
bpeters5814 is offline   Reply With Quote
Old 11-06-2011, 11:34 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Sweet that's pretty cool and looks great as well. You made it look pretty easy as well haha
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 11-07-2011, 01:18 AM   #5
Pop's C-10
Pop's C-10's Avatar
very nice mod
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 11-07-2011, 01:27 AM   #6
stich626
much better way and be able to keep the tape deck would've been a speaker selctor switch (radio shack) you can also do this with older aftermarket radios that have a c/d changer plug..
or go the real easy way and use the older walkman catt tabe adapter that plays through the tabe decks head.. and yes they still make them and market them for the i pods
stich626 is offline   Reply With Quote
Old 11-07-2011, 07:42 PM   #7
marc54
Thanks everyone. Didn't really want to keep the tape deck around, let alone not knowing if it even worked. And this mod only costed $6 at Radio Shack.
