Old 11-03-2011, 09:04 PM   #1
Fan2zee
Fan2zee's Avatar
Headlights: low & high beam
Just picked up an 87' R10. It appears my top & bottom head lights are updated to use 9007 H5 bulbs. In which both top & bottom have these bulbs installed. And I have square running lights in the grille.
Question:
High beam, all lights should be on? If so, which lights should be brighter top, bottom, neither?
Low Beam, Top lights should be on?
Should I be running different bulbs in the low beam vs high beam?
Fan2zee is offline   Reply With Quote
Old 11-04-2011, 01:43 AM   #2
Your41Plague12
Your41Plague12's Avatar
Re: Headlights: low & high beam
Question:
The top lights should be the low beams, the bottom should be the high beams. They should all be on when the high beams are activated, and the lowest of the headlights should be the brightest. The low beams are different from the high beams, they require a 3 prong plug versus a 2 prong.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 11-04-2011, 03:51 AM   #3
Fan2zee
Fan2zee's Avatar
Thanks: Too clarify last sentence, low beam = 3 prongs & high beam = 2 prongs?
87' R10
Old 11-04-2011, 03:58 AM   #4
bigwheel15
bigwheel15's Avatar
Right
bigwheel15 is offline   Reply With Quote
Old 11-04-2011, 04:02 AM   #5
Fan2zee
Fan2zee's Avatar
My lights are now in the proper sequence. I think they need to be adjusted due to low beams are aimed too high vertically, which make oncoming drivers think they are brights. And high beams are aimed too low vertically, giving me the improper angle affect in which a high beam should.
87' R10
Old 11-04-2011, 04:09 AM   #6
Fan2zee
Fan2zee's Avatar
Originally Posted by bigwheel15 View Post
Right
Got It.
Both of my low/high bulbs are identical with 3 male prongs, but the female plugs coming from the truck are wired different. Low beam has 3 wires (one for each prong)? High beam has 2 wires (lacking one wire, making it a 2 prong plug)?
87' R10
Old 11-04-2011, 07:03 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
in the corner of the headlight buckets there is a tab to prevent putting the wrong bulb in
if these tabs arn't bent the high beam lights won't line up right,in the low beam spot
and the same in reverse order
In my pics I've changed the low to the bottom and the high on top
with no issues
just by bending those bucket tabs,and of course you switch the plugs too
I think it would look cool on a lowered truck....
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 11-04-2011, 09:30 AM   #8
Fan2zee
Fan2zee's Avatar
with no issues
My truck is lowered & I tried that swap. I agree it looks better with low beams on bottom. Just had to re-tweak the alignment. Thanks to the all info that was replied. And even better, I didn't have anyone flashing their lights at me today.
87' R10
Old 11-05-2011, 03:32 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
Post up a pic, lets see how it looks,others might like it
John
Old 11-08-2011, 07:10 PM   #10
Fan2zee
Fan2zee's Avatar
Here is a pic, with the low beams on the bottom...
87' R10
Old 11-08-2011, 07:34 PM   #11
kwin
kwin's Avatar
nice!
kwin is offline   Reply With Quote
Old 11-08-2011, 10:41 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
Thanks it looks great really adds to it I think!And red too
John
Old 10-11-2013, 08:19 PM   #13
iceship
I thought all 4 lights are to be on when deam... .
iceship is offline   Reply With Quote
Old 10-11-2013, 09:39 PM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
two on for low, and all four on high.
but now the low beams are now in the bottom buckets.
engage the high beams and adjust them up from the lows.
other gm cars run same bulbs ,the same way , just inside ,outside, not up down
I did this on my firebird ,camero, lemans ,grand prix .
it's looks cool.
but I rewire to run headlights only first pull , second adds the tails.
John
Old 10-12-2013, 12:04 AM   #15
iceship
While I would like all 4 dimmer lights on. ..
Old 10-12-2013, 02:14 PM   #16
motornut
78K & 79C Jimmys
motornut's Avatar
well the two high lights (2 wire bulbs)would have to be swapped and wired to a second set of lows(3 wire bulbs)
1. not sure if it could handle it's extra power "pull" with out more mods
2.you might get pulled over/checked out more,and flashed from oncoming traffic,since your truck would appear to allways have the high beams on all the time
John
Old 10-12-2013, 09:20 PM   #17
iceship
I'm quite sure my 87 was like that. ...
Old 10-12-2013, 11:31 PM   #18
motornut
78K & 79C Jimmys
motornut's Avatar
oh, ok my 87 wasn't.
John
Old 10-13-2013, 11:06 AM   #19
LONGHAIR
That would be a perfect place to use relays, but as others have mentioned, it might get you pulled over or at least flashed a lot more often.
I'm not sure that I follow the logic of lowering the lights on a lowered truck though? Lifted truck, yes
Back in the day when the "lift laws" were implemented here in Ohio, headlight height was one of the limitations. Some guys would put covers over the original locations and put the round style regular headlight bulbs into off-road light housings (KC lights)
That didn't last very long though, they came out with frame height measurements based on GVWR after that.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
