11-03-2011, 11:24 PM | #1 |
MOTORHEAD!
What will it run?
My 82 LWB with a 700hp BBC, TH400, 3.50 gear, 10" slick, 3200 stall, and leaf spring suspension... Not racing til spring.. Ask for more info if so required!!!
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph |
11-03-2011, 11:43 PM | #2 |
The Engine Whisperer
Re: What will it run?
14.3
11-03-2011, 11:49 PM | #3 |
fast! if you can hook
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
11-04-2011, 05:37 AM | #4 |
How tall are the slicks? How big is the convertor 10" 9" 8"? Just plain leafs are did you add cal-trac bars? What is your torque peak?
11-04-2011, 09:47 AM | #5 |
you have the power to weight ratio to run mid to high 12's with good traction/ and no wheel hop
11-04-2011, 10:51 AM | #6 |
MOTORHEAD!
30 inch tire, leafs with cal tracs, 10" converter
11-04-2011, 10:52 AM | #7 |
MOTORHEAD!
Torque peak of 680 at 3600
11-04-2011, 12:13 PM | #8 |
On a budget like Fred Sanford
That's a tall tire for a 3.50 gear.....what's your HP peak rpm?
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
11-04-2011, 12:15 PM | #9 |
MOTORHEAD!
6300ish... Going to be a driver, not a racer... Hope to get 10mpg out of it!
11-04-2011, 11:31 PM | #10 |
Low 11's
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
11-04-2011, 11:34 PM | #11 |
what engine/trans setup are you running to get in the 10's .....damn fast truck !!
11-04-2011, 11:41 PM | #12 |
Look at the the Pass Time link in my signature.
11-04-2011, 11:48 PM | #13 |
MOTORHEAD!
That's what I'm hoping for djracer!
11-05-2011, 06:17 PM | #14 |
My engine is 699 hp it runs 11.18@ 124mph. It hooks super hard.
Posted via Mobile Device |
11-05-2011, 09:04 PM | #15 |
MOTORHEAD!
Well I hope to run 11.5 or better with skinny's up front and stickies out back... I am putting the fuel cell at the front of the box because I would hate to ruin usage of the box if it were at the back... I have considered the "spare tire location", but with the possibility of reloacting leaf springs in the future, I doubt they would fit with the tank there...
My goal is to keep this truck as stock appearing as possible, minus a cowl hood and a roll pan... Any suspension tips/weight savings tips would be MUCH appreciated!
11-05-2011, 11:21 PM | #16 |
buddy has similar set up as you. He is 11.7-11.9 depending on conditions
11-06-2011, 01:16 AM | #17 |
Mean Green
Properly geared and a 13.5w tire with a correctly matched converter, a 700Hp motor should run 10.90's to 11.teens in a truck that weighs in 3600-4000lbs
427 SBC 683HP & 590ftlbsTRQ @ fly wheel. 60'-1.38 1/4-10.43 MPH-124.6 New ET current 4/2019 AKA MEAN GREEN. |
