Vacuum modulator line question??
I am installing a TH350 in a 69 C-10 longbed with a 350 engine.
The truck originally had a 3 on the tree. I don't have a modulator line for this transmission. I assume that originally there was a pre-bent line, with rubber hose on the ends to attach to the manifold and modulator??? 1. Am I correct in that assumption? 2. Can I simply run a length of 5/16" vacuum line to make this connection? With the modulator facing towards the rear, it seems like I would have to have a fair amount of slack in the line, in order not to kink it. 3. anyone have a spare line or a suggestion for a good source? TIA, Mike |
#2 | |
The Older Generation
Re: Vacuum modulator line question??
![]() Join Date: Jan 2008
I'd go to the local pick n pull and browse and see what they might have. It would probably be on some of the older cars.
Rubber all the way might collapse easily and not get a good vacsignal. Of course that probably would'nt happen right away
I have used DOT 1/4" plastic air line for this with a little rubber hose on each end. DOT air line is tough stuff.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
Thanks for the quick responses, folks.
We are running a piece of hose just for today, to take a test drive and assess everything. Sometime this weekend I will get some tubing and bend a new one. Thanks again, Mike |
