Old 11-04-2011, 12:35 AM   #1
bigblock68
bigblock68's Avatar
car pattern rotors??
I'm changing my 69 over from 6 lug disc brakes to 5 lug.....does anybody sell a direct bolt on rotor that is 5 on 4-3/4.The choice of wheels seems endless.also is there any problems going with the smaller pattern when i have the rear axles done??
bigblock68 is offline   Reply With Quote
Old 11-04-2011, 01:23 PM   #2
70BLAZERX2
Re: car pattern rotors??
71-74 G10 chevy vans ,some used the light brakes with the 4 3/4 bolt pattern.. I do not know if the bearing size is the same..but it should be..that will be one to try..
Its the same rotor as the 77 caprice..This may work for you.
70BLAZERX2 is offline   Reply With Quote
Old 11-04-2011, 02:06 PM   #3
faribran
i am in the middle of doing this... i had the front truck rotors redrilled for the 4 and 3/4 pattern.. the only problem i am having is the inner wheel making contact with the lower a-arm.
faribran is offline   Reply With Quote
Old 11-04-2011, 02:31 PM   #4
Rochlow
Actually, a board member sell rotors for 67-72 trucks that use a 5 on 5 3/4 bolt pattern.
http://67-72chevytrucks.com/vboard/s...d.php?t=489190
Rochlow is offline   Reply With Quote
Old 11-04-2011, 03:39 PM   #5
cleanfreak
cleanfreak's Avatar
81-87 light duty spindle , ball joints , etc. , use a 1987 camaro h.d. brake rotor , 5x4 3/4 pattern with 12mm studs , done this a couple times with all factory stuff
cleanfreak is offline   Reply With Quote
Old 11-04-2011, 07:20 PM   #6
OARNGESI
OARNGESI's Avatar
HERE YOU GO http://www.performanceonline.com/DIS...K-5514/?page=1
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
