11-04-2011, 09:17 AM | #1 |
WANTED: Complete rear axle for 1965 C-10
Hey All,
I'm looking for a complete 12 bolt rear axle assembly for my 1965 C-10 build. I know other years would work, I think I can use anything from 64-72, but correct me if I'm wrong. Gear ratio is not important, but would be more interested in something that has 3:73 or lower, limited slip another plus. I can set-up freight. Thanks! Chris Aunchman |
11-04-2011, 09:27 AM | #2 |
Just a Member
Re: WANTED: Complete rear axle for 1965 C-10
I have two Dana60 but I think they are both 10 bolt... I will check... You pretty much set on 12???
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
11-04-2011, 09:31 AM | #3 |
I have a 12 bolt from a 1967 C10, needs rebuilding as the ring and pinion are well worn.
Has drums that look good and all the misc brake parts.
Make it a great day! Mike |
11-04-2011, 01:02 PM | #4 |
Do the Dana 60's have the pads for the trailing arms or leaf springs?
11-04-2011, 01:03 PM | #5 |
How much are you asking?
11-04-2011, 01:13 PM | #6 |
Just a Member
Chris... It just depends on the suspension I believe... The two I have are for leaf setups... the one I am getting monday is for rear coil springs
11-04-2011, 02:53 PM | #7 |
The style I would need would be for the trailing arms. Let me know the condition of the one you get on Monday.
11-04-2011, 03:46 PM | #8 |
My rear end is a trailing arm, 6 lug, needs a new ring and pinion. Has emergency brake cables, drums and all the misc brake parts. The drums are rusty so I don't know if they are in spec.
$200 + freight.
11-04-2011, 07:20 PM | #9 |
Just a Member
Yes it is from a 69 C-10 with 6 lug and coil spring setup... I will shoot ya pics ASAP Monday... I really would like to move it as soon as I get it to recoup some of my overhead... Th truck runs so I will be giving it a spin for ya! And it was confirmed it is a 12 bolt as well!!! YEPPERS!
11-07-2011, 08:04 AM | #10 |
What ratio is it?
11-08-2011, 10:28 PM | #11 |
Just a Member
I got the truck... The rear is in GREAT shape... Smooth shift and no slop... I will pull cover tomorrow to get ratio... Let me know
11-09-2011, 01:41 AM | #12 |
If you still r looking I am going to have a 6 lug 12 bolt complete from a 67 with trail arms and all have not cut it away from frame yet and will need to verify ratio $200. Plus ship or you pick it up in NJ
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
11-09-2011, 07:45 AM | #13 |
If the others do not work out and you can ship, I have a 6 lug, coil spring susp. 1968 C10 12 bolt with 3.73 gear ratio. It is an open trac. I pulled it from my truck that I have drove for 20 years and had 137,000 miles on it. The brakes are good. I removed it to install a 72 5 lug rear end because I went to disc brakes. Thanks
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
11-09-2011, 01:20 PM | #14 |
[I] I got the truck... The rear is in GREAT shape... Smooth shift and no slop... I will pull cover tomorrow to get ratio... Let me know
Cool let me know the ratio... |
11-09-2011, 01:21 PM | #15 |
"If you still r looking I am going to have a 6 lug 12 bolt complete from a 67 with trail arms and all have not cut it away from frame yet and will need to verify ratio $200. Plus ship or you pick it up in NJ"
What is the ratio? How good of shape is the rear case in? |
11-09-2011, 01:21 PM | #16 |
"If the others do not work out and you can ship, I have a 6 lug, coil spring susp. 1968 C10 12 bolt with 3.73 gear ratio. It is an open trac. I pulled it from my truck that I have drove for 20 years and had 137,000 miles on it. The brakes are good. I removed it to install a 72 5 lug rear end because I went to disc brakes. Thanks "
The case looks good.....How do the gears look? Would it need new gears? |
11-09-2011, 01:49 PM | #17 | |
11-09-2011, 02:56 PM | #18 |
Just a Member
The results are in..This thing look-a-real nice.. Fluid was not bad at all... 3.73 gears...All writing on ring gear is still legible...as you can tell by the pics the gears are awesome shape.
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog Last edited by HeavyMetalChevy; 11-09-2011 at 02:58 PM. Reason: pics |
11-09-2011, 03:12 PM | #19 |
Roadtrip!
I have a 4:11 open from a 66 with coils. Came out of a forestry truck. (1/2 ton) $150
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
11-12-2011, 04:57 PM | #20 | |
Gears look good but the case looks like it is in tough shape.... |
11-12-2011, 08:02 PM | #21 | |
Just a Member
11-13-2011, 01:05 AM | #22 |
Oh I meant the housing (axle tubes), I just want to make sure it will clean up nicely.
11-13-2011, 01:13 AM | #23 |
Just a Member
Oh yeah man.... People think I am crazy but I clean ALL my parts... I am OCD like that... I can not ship "messy" things... I have powerwashed steering boxes, ac/heater boxes, carboard boxes, bolts, nuts...lol you get the point... How was you going to arrange ship?
11-16-2011, 09:51 AM | #24 |
Just a Member
Hey bro...just checking in.... You still looking???? I have a buddy coming in for the holidays and I can possibly have him lift the rear back east with him..He is in D.C. area... cuts trip from here in half
11-16-2011, 10:57 AM | #25 |
Actually I had a local guy pull through for me. He just got something in and called me about it. Thanks though!
Chris |
