Old 11-04-2011, 09:21 AM   #1
Arl37
How to reattach Brake Pedal Return Spring?
Disconnected the Brake Pedal Return Spring to replace Brake Booster Pushrod Firewall Boot. Really strugging to reattach the spring. Anyone got any tips on how to reattach?
Arl37 is offline   Reply With Quote
Old 11-04-2011, 10:30 AM   #2
dan42
dan42's Avatar
Re: How to reattach Brake Pedal Return Spring?
The way to take it off is to put spacers (such as screwdrivers) in the coils to keep it expanded - that works for hood springs. You might be able to do it now but it would be easier if you could extend it somehow and get the screwdrivers, etc in the coils, then install it.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 11-04-2011, 10:53 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Does that work? Makes me want to remove a hood spring to test it.
As long as I've worked on mechanical things and as old as I am, I still learn something new.
68gmsee is offline   Reply With Quote
Old 11-04-2011, 12:29 PM   #4
domeier
domeier's Avatar
As long as I've worked on mechanical things and as old as I am, I've learned that springs are always trying to KILL ME!
domeier is offline   Reply With Quote
