Old 11-04-2011, 12:15 PM   #1
pstifel
gauge cluster wiring pin removal
ok, one more question and then I'll go away.
I have to rearrange a few gauge cluster pins in the harness to accommodate a different gauge cluster. Anyone know how to remove the wires (pins) from the gauge clip ghat plugs in the back of the cluster?
Thank you Thank you Thank you.
Peter
pstifel is offline   Reply With Quote
Old 11-04-2011, 12:46 PM   #2
Stepper86
Stepper86's Avatar
Re: gauge cluster wiring pin removal
The connection pins have a little hook that grabs on to the plastic, I pushed the hook back a little with a needle. Then carefully wiggled them out. Canīt remember if they go back towards the cables or forward.
Tom.______________________________________
The fleet:
2007 BMW 530xi M (daily driver)
1986 C-10 Stepside (project "my time")
1992 Corvette cab (summer time daily driver)
1969 Cadilac DeVille Cab ("it just need some paint")
Stepper86 is offline   Reply With Quote
Old 11-04-2011, 12:54 PM   #3
Jonboy
Slots go on anything!
You can buy a specialty tool for that as well (it's also an excuse to buy tools....). I have also used a straightened out small paper clip. Basically push the wire up into the connector, release the tab with the tool of your choice, and pull the wire back.
p.s.- stay as long as you like. No need to go anywhere.
1974 Jimmy- 5.3/4L80e/NP241
Old 11-04-2011, 01:04 PM   #4
pstifel
great! thanks, I'll give it a try.
