Old 11-04-2011, 06:24 PM   #1
1972GMCSUB
? Will a 1979 3/4 Ton Chevy front end directly bolt into my C20?
A friend has a 1979 3/4 ton that he's parting out and willing to sell me the complete front end. It looks like it unbolts completely whereby I could take and bolt into my 1969 C20 Suburban with no modification. My drum brakes work great, but if I could get 3/4 ton disc brakes up front, I'd prefer that.
Any advice is appreciated.
Thanks,
Chris
'66 GMC Custom Deluxe Suburban
'69 C20 Suburban
1972GMCSUB is offline   Reply With Quote
Old 11-04-2011, 09:07 PM   #2
Geezer
Geezer's Avatar
Re: ? Will a 1979 3/4 Ton Chevy front end directly bolt into my C20?
Probably so, when I pulled the front cross member/ suspension assembly out of an 88 1/2 ton suburban and bolted it under my 67 1/2 ton GMC PU, two bolt hole were 1/2 a hole off and two were a whole, hole off but all the rest were dead on! That's 21 years apart and it bolted up with disc brakes and a faster ratio, high effort power steering, cheaper bushings and ball joints, and a large diameter anti sway bar. Auto zone has a complete new 71 chevy PU power brake master/booster combo that was in the $200 range a half dozen years ago. that bolts up and works perfect at least on a 1/2 ton..
If you can't drive it park it! If you can't park it milk it!
Geezer is offline   Reply With Quote
Old 11-05-2011, 02:23 AM   #3
1972GMCSUB
Thanks Geezer! I have the power brake booser, but not thr factory heaby duty sway bar.
Regards,
Christiaan
'66 GMC Sub
'69 C20 Sub
Old 11-05-2011, 02:47 AM   #4
laid_out_70
laid_out_70's Avatar
it should. i have 86 c20 control arms and spindles on my 70 c20
My Build Thread. 70 C-20, SFBD, angled Z, 3 linked. impressive for a noob?
http://67-72chevytrucks.com/vboard/s...d.php?t=438132
laid_out_70 is offline   Reply With Quote
Old 11-05-2011, 06:36 AM   #5
1972GMCSUB
Oops, I meant my '69 doesn't have the sway bar. I don't think Late now, I'll check in the am. But that '79 that I might get has the sway bar. It's massive.
Christiaan
'66 GMC Sub
'69 C20 Sub
Old 11-06-2011, 01:10 PM   #6
Geezer
Geezer's Avatar
I had a 69 panel delivery back in 1973. When I got it, the thing cornered like a boat then I noticed it didn't have an anti sway bar. Don't know why, but I could tell it never had one because of the rivets on the frame. I pulled a bar form a junk yard truck and installed it on the panel and it drove much better!
