Old 11-04-2011, 08:08 PM   #1
BLOWN72
Low profile air cleaner
I am looking for a low profile air cleaner, what do you recommend? I know when I put my cowl hood I still won't have a lot of clearance so looking for something.
1972 C10 SHORT BED, BLACK ON BLACK, ZZ3 CRATE MOTOR WITH B&M 250 SUPERCHARGER, HEADERS, 350TURBO TRANS, BOOST RETARD, POSI, 373 GEARS
1966 MUSTANG COUPLE, 289 HIPO MOTOR, CAM, 650 HOLLEY CARB, FULL LENGTH HEADERS, 2.5" FLOWMASTER EXHAUST, HURST SHIFTER, 373 GEARS POSI
2006 MONTE CARLO, FLOWMASTER MUFFLERS, K&N INTAKE, EXTERIOR MODS
BLOWN72 is offline   Reply With Quote
Old 11-04-2011, 08:51 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Low profile air cleaner
You should be abdle to put any air filter you want under a stock hood assuming you don't have a high rise intake.
I've had small blocks, big blocks, even massive caddy big blocks and have always run a tall air filter under a stock hood. Always had a spacer under the carb too.
big block chevy under a sloped 67/68 hood;
Cad big block. (now it has a stock one on it)
and another angle;
I can't find any better shots of the old small block truck, but it had a performer RPM intake (semi-high rise intake) with a spacer under the carb, AND a spacer under the air filter with a filter as tall as in the other photos, and stll (usually) had a stock hood covering it all.
You have PLENTY of air filter room.
Old 11-04-2011, 09:34 PM   #3
hjewell2
hjewell2's Avatar
Here is a pic of mine with a 4'' tall cleaner 1'' spacer and a edelbrock performer.
hjewell2 is offline   Reply With Quote
Old 11-05-2011, 01:24 AM   #4
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
Guys from reading his username I would assume his truck is blown....
screamin_c10 is offline   Reply With Quote
Old 11-05-2011, 01:29 AM   #5
screamin_c10
Spectre has some pretty cool carb hats that are low profile, they also have cold air systems for hot rods as well.... All of which would fit under your cowl hood even with your huffer....
Old 11-05-2011, 01:40 AM   #6
SS Tim
SS Tim's Avatar
You should have a lot of room even with the supercharger. On my '72 402 Suburban I stacked two 3.5" elements and had room left over. Have you measured the actual clearance? Might not have a problem.
SS Tim is offline   Reply With Quote
Old 11-05-2011, 07:13 AM   #7
Give details on exactly what you have and even a picture. I think that would help.
Old 11-05-2011, 10:06 AM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
What size blower are you running there are a few trucks on here that are running the smaller blowers with cowl hoods and have simple air cleaners on them... Sctojims truck I believe is one of them..
Never mind I see you have a 250 supercharger..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-05-2011, 10:11 AM   #9
FRENCHBLUE72
PROJECT 7DEUCE
Jims set up
MEMBER #6377
Project "7DEUCE"
Old 11-05-2011, 10:23 AM   #10
cdowns
cdowns's Avatar
weber sidedraft carbs
Old 11-05-2011, 11:08 AM   #11
capev86
yeah...plenty of room under these hoods for most setups.
i ditched the 2bbl on my 72 C20 burb in favor of a q-jet. i knew i wanted to run the big air box saved from my dad's 84 burb 350 w/ tow package but i updated the bottom half with a dual snorkel unit (thank GM for parts bin engineering). this sucker takes a 14x5 filter and will flow enough air for your average race motor. no chance of choking off that 307 while towing! just need to get it painted up pretty one of these days. oh...and i prefer an enclosed filter as it cuts down on dirt, mud and engine grime getting thrown up on the filter.
[IMG][/IMG]
capev86 is offline   Reply With Quote
Old 11-05-2011, 03:29 PM   #12
BLOWN72
I have a zz3 crate motor with a B&M 250 supercharger, and it barely doesn't fit under the stock hood.
Old 11-05-2011, 08:43 PM   #13
gonnuts
gonnuts's Avatar
http://67-72chevytrucks.com/vboard/a...1&d=1320539967
67 Chev SWB, 400 SB .040 over, vortec heads, comp XE268 cam, performer EPS intake, edel. 650 AVS carb, 700R4
gonnuts is offline   Reply With Quote
Old 11-05-2011, 09:16 PM   #14
Check with member Hart Rod.
His 68 has a blown motor, but I don't see exactly what air cleaner he used.
http://67-72chevytrucks.com/vboard/s...d.php?t=370973
Old 11-06-2011, 02:24 AM   #15
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I have a drop center 14x3 edelbrock air cleaner on mine now. The drop center gets you an inch or two lower.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 01-07-2014, 05:27 PM   #16
lenguini
lenguini's Avatar
Is this a 14" Cleaner ? Just curious.....Im shopping !
Always a place in my heart for old Chevy trucks:
My build thread-project truck dream 65"
http://67-72chevytrucks.com/vboard/s...d.php?t=510863
lenguini is offline   Reply With Quote
