Old 11-04-2011, 08:21 PM   #1
Hduramax
Hduramax's Avatar
who makes a 5"/7" drop for a 69
any one know < I am having a little trouble finding one> who makes a 5"/7" drop for a 69 c-10 with springs trying to steer clear of bags thanks for any help
2008 HD
2010 Camaro 2ss (The Wife's Ride)
2005 Suzuki GSX-R 1300 "Busa"
1969 C-10 (under Construction)
2013 Sonic LT
"LIVE LIFE,TASTE DEATH"
Hduramax is offline   Reply With Quote
Old 11-04-2011, 08:27 PM   #2
shawno72
C/10 junkie
shawno72's Avatar
Re: who makes a 5"/7" drop for a 69
You could do 6" springs out back with 1" blocks. In front ECE drop spindles and 2" springs will give you a 5 1/2" front and 7" rear.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 11-04-2011, 08:32 PM   #3
Lonnie07
This is the set up im thinkin about do. does anyone have pics. An can u run the inner wheel well an hows it turn?
Lonnie07 is offline   Reply With Quote
Old 11-04-2011, 09:14 PM   #4
shawno72
C/10 junkie
shawno72's Avatar
I have run this setup with 15" wheels and p235/70r35 tires with plenty of clearance. You will want to c-notch the rear otherwise you will bottom out the axle tubes on the frame on hard bumps. But as for the front I could do u-turns over speed bumps and not rub. Just make sure you leave the lower control arm bump stops in. By the way ECE aka Early Classic Enterprises will have all you need for this drop. Great guys.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 11-07-2011, 08:46 AM   #5
Lonnie07
Thanks alot bud
Old 11-07-2011, 01:16 PM   #6
shawno72
C/10 junkie
shawno72's Avatar
No problem. Glad to help.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 11-07-2011, 04:59 PM   #7
tubbedII
needs more $$$
tubbedII's Avatar
I think the OP was looking for an all in one kit for a 5/7 drop, and I don't think anyone sells this drop as a kit.
If I were to do a 5/7 and didn't have any parts, I'd do a 3" spindle (swapping the BJ's since the 3" is only available in the 73+ where 72- only go 2.5") with a 2" spring for the front and a 5" spring with a 2" block in the rear including a c-notch, super track bar and shock relocators. I'd like to have the tallest spring in hopes for the best possible ride.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 11-07-2011, 06:19 PM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
CPP super slam is as close as you'll get to a full kit
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-07-2011, 10:03 PM   #9
Hduramax
Hduramax's Avatar
thanks for the help guys
2008 HD
2013 Sonic LT
