11-04-2011, 09:34 PM | #1 |
Dually wheels????
What will interchange with the square body trucks? Later GM, Ford or Dodge?
11-05-2011, 12:08 PM | #2 |
Re: Dually wheels????
All GM, All Dodge, and Ford untill 95
1949 Five Window, 1973 Step Side, 2000 Z71 |
11-05-2011, 12:10 PM | #3 |
C35 Crew Dually
are there not hub bore diffrences?
and GM after 2010 wont.
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
11-05-2011, 12:38 PM | #4 |
I'll first clarify that I'm no expert on dually's but did some investigating for wheel choice options.
The hub bore is different between GM & Dodge (older vs newer wheels) despite the same bolt pattern. Not an issue if its a lug centric wheel (aftermarket) but most duallys use both the hub & lug for locating the OE type wheel. Ford's hub bore is much larger & not interchangeable from what I researched. This is typically why wheels are offer for GM/Dodge applications & a Ford option. All the newer GM wheels from around 08 to present are different (metric?) patterns as well. The list was something like this.... GM apps: 73-00; 01-07; & 08 -current Dodge: 7x-02; 03- current I don't have the Ford info on hand as it was different enough I completely ruled them out as a 'cheap' alternative.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-05-2011 at 12:50 PM. |
11-06-2011, 09:23 AM | #5 |
Here you go...
Chevrolet/GMC Code: Year Size Bolt Pattern Lug Size Center Bore Thru-81 16x6 8x6.5 1/2R 4.567 82-87 16x6 8x6.5 9/16R 4.567 88-00 16x6 8x6.5 14x1.5R or 9/16R 4.567 01-02 16x6 8x6.5 14x1.5R 4.887 *2002 and newer Chevrolet Duramax dually requires use of short shank lugs. Dodge Code: Year Size Bolt Pattern Lug Size Center Bore 92-99* 16x6 8x6.5 5/8R or 9/16R* 4.773 00-02 16x6 8x6.5 9/16R 4.773 *Dodge Dually 92-99 requires a change to Ford rear inner wheel or non-coined Dodge inner's. **Can either be 9/16R or 5/8R (some come with 5/8L on left rear) ***Ram 3500 94-on uses 9/16R lugs. Ford F-350 ONLY Code: Year Size Bolt Pattern Lug Size Center Bore Thru-98* 16x6 8x6.5 9/16 R/L* & 9/16R* 4.883 99-on 16x6 8x170 14x2.0 or 14x1.5 4.930 *Will not fit Ford applications with coined centers or axle pins. **Ford F-350 dually 81-84 uses 9/16 LEFT hand lugs on left rear only. ***Ford F-350 dually 85-on uses 9/16 RIGHT hand lugs. |
11-09-2011, 01:32 PM | #6 | |
11-09-2011, 11:30 PM | #7 |
Help!
11-11-2011, 02:45 PM | #8 |
11-11-2011, 02:56 PM | #9 |
Does anyone know of a good picture reference detailing the 'coined' surfaces? I've heard of this, but have never seen it first hand.
11-11-2011, 02:57 PM | #10 | |
thanks |
11-11-2011, 03:27 PM | #11 | |
right in the owner’s manual for the truck. It says to use two 5/8-18 acorn lug nuts to center the wheels on the studs and then put the other lug nuts on. After they are tight remove the 2 acorn lug nuts and replace with yours and torque to spec. Last edited by Desert1957; 11-11-2011 at 03:33 PM. |
