Old 11-05-2011, 04:41 AM   #1
brichard
Antenna Delete
Is there such a thing as an Antenna Delete Plate?
I dont have a radio and have installed a radio delete plate, and the antenna is in bad shape.
An Antenna Delete Plate, if there is such a thing, would provide an option to replacing the antenna.
brichard is offline   Reply With Quote
Old 11-05-2011, 05:39 AM   #2
heeroyue2002
fat old dude
heeroyue2002's Avatar
Re: Antenna Delete
im not sure. ive had cowls with no antenna holes though.
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 11-05-2011, 05:54 AM   #3
cdowns
cdowns's Avatar
Re: Antenna Delete
in most cases the antenna came from the factory along with the mirrors on the front seat and were dealer installed . cowls came witout holes ,holes were drilled and antenna installed during dealer prep to deliver new vehicles
Old 11-05-2011, 12:15 PM   #4
brichard
Re: Antenna Delete
That is what I was expecting to hear.
But, I imagine someone must have had the same scenario and came up with an easy solution.
For instance, are there any flat rubber plugs that might be inserted to provide a solid seal?
Old 11-05-2011, 12:19 PM   #5
cdowns
cdowns's Avatar
Re: Antenna Delete
measure size of hole go to hardware store and look thru the bins also boat supply store or even radio shack might have block offs
Old 11-05-2011, 12:21 PM   #6
TX72C10
Re: Antenna Delete
I would think you could use a firewall plug and just use a dap of silicone before installation.
My Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=492290
TX72C10 is offline   Reply With Quote
Old 11-06-2011, 07:24 AM   #7
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Re: Antenna Delete
Best way is to replace the cowl with a no hole version. I just found one in a junkyard near me that looked in good condition.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 11-06-2011, 09:45 PM   #8
flashed
Re: Antenna Delete
Or you can do like I did and have the bodyshop weld in a plug of metal and its gone for good.
flashed is offline   Reply With Quote
Old 11-06-2011, 09:50 PM   #9
Rochlow
Re: Antenna Delete
And if you weld it closed, a quarter makes a perfect filler patch. Trick I learned from an old school body guy.
Rochlow is offline   Reply With Quote
Old 11-07-2011, 01:11 PM   #10
406 Q-ship
406 Q-ship's Avatar
Re: Antenna Delete
A Quarter is not made of steel so it will not weld in. I bet the body guy used a quarter to mark out a plug to cut from sheet metal, not the quarter itself.
My truck is a no radio truck and it just does not have the hole for the antenna.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 11-07-2011, 01:44 PM   #11
Rochlow
Re: Antenna Delete
That's a quarter welded in there.
Old 11-07-2011, 08:41 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Antenna Delete
I doubt the antenna was installed at the dealer. The mast might have been, but the hole was punched not drilled. Every cowl I have seen that had a factory antenna on it had a punched hole with a notch, and always in the same location. I just went out and snapped a pic of the cowl on my burb. It came with an AM radio, and has no antenna on it at the moment. I welded up the exact same hole in the cowl on my Longhorn. While my C/30 was a radio delete truck, the cowl came off my old '70 CST/20 Longhron that still had the original AM radio under the seat when I bought it.
I just discovered I cant post a pic from my i phone... I'll try to get the photo posted from my laptop later.
Old 11-07-2011, 11:25 PM   #13
Longhorn Man
Re: Antenna Delete
'72 burb cowl
Old 11-07-2011, 11:51 PM   #14
ls1nova71
ls1nova71's Avatar
Re: Antenna Delete
You can't weld a quarter to steel. Maybe you could braze it, but that looks MIG'd to me. I'm.with 406 Q-ship, he probably used it as a template.
ls1nova71 is offline   Reply With Quote
Old 11-08-2011, 07:05 AM   #15
heeroyue2002
fat old dude
Re: Antenna Delete
my 71 cst had no radio antena on the cowl. instead it had a different type on the side of the driver cab.
Old 11-08-2011, 07:46 AM   #16
Rochlow
Wink Re: Antenna Delete
He would be me.. Yes I mig'd it in there. I saw it done on a dozen gm cars from the 60s when I was younger. And tried it myself for giggles. It worked.
Old 11-08-2011, 04:23 PM   #17
406 Q-ship
406 Q-ship's Avatar
Re: Antenna Delete
There is no STEEL in any US coins (except the WWII pennys) There is no way a mig welder will work on a US Quarter.
The current clad version is two layers of cupronickel (75% Copper, 25% Nickel) on a core of pure copper[2] giving a total composition of 8.33% Ni with the remainder Cu, weighs 5.670 grams (0.2000 avoirdupois oz, 0.1823 troy oz), diameter 0.955 inches (24.26 mm), width 1.75 millimeters (0.069 in) with a reeded edge.
Old 11-08-2011, 06:05 PM   #18
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Question Re: Antenna Delete
Ummm, so if that's the case how did he Mig it in there?
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 11-08-2011, 08:23 PM   #19
TrkEnvy
Re: Antenna Delete
It's being held in by the boogers on that weld job and a bunch of jb weld underneath it lol
TrkEnvy is offline   Reply With Quote
Old 11-08-2011, 08:29 PM   #20
Rochlow
Re: Antenna Delete
Hey thanks..
Old 11-08-2011, 09:58 PM   #21
70-Shorty
Re: Antenna Delete
does anybody wanna sell an "antenna delete" PLAIN no hole cowl?
Ontario CA•70 Chevy Shortbed Fleetside C-10
71 Chevy Longbed Fleetside C-20 (sold )
63 Chevy II Nova SS
02 Ford F-150 Harley-Davidson supercharged 5.4
2000 Harley Roadking Hot Bike Baggers Mag Shoot
http://s263.photobucket.com/albums/i...oot/?start=all
some truck lettering & flame jobs
http://www.flickr.com/photos/4950319...7602894916215/
70-Shorty is offline   Reply With Quote
Old 11-09-2011, 02:06 PM   #22
406 Q-ship
406 Q-ship's Avatar
Re: Antenna Delete
Then show me where there is a steel quarter, where to buy a nickel/copper mig welder, or a cowl made of nickel/copper. P.T. Barnum used to have a mermaid in it his freak show too, don't make it right or true.
To that picture: I can not tell if it is a quarter in the picture, assuming that it is........it could be silver soldered to the cowl.
Old 11-09-2011, 02:56 PM   #23
big mike71
big mike71's Avatar
Re: Antenna Delete
I thought that mermaid was real, now you've ruined one of my best childhood memories.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 11-09-2011, 03:59 PM   #24
Rochlow
Re: Antenna Delete
It's not soldered.
Old 11-09-2011, 07:50 PM   #25
bobs409
bobs409's Avatar
Re: Antenna Delete
Sending PM.
Bob
