Old 11-05-2011, 12:35 PM   #1
kilomanjaro
kilomanjaro's Avatar
Clutch Fork Install Question
I have a 72 blazer 4x4 with a sm465 4 speed. The tcase and tranny were already in the truck and I goofed and installed the motor without putting the clutch fork in. Can the clutch fork be installed without removing the transmission or motor? It looks like I can disengage the clutch (read pry on the throw-out bearing) a tad and almost do it....anybody ever try this? Otherwise I am pulling the motor back out.
John
63 Buick Wildcat 425
72 Chevy Blazer CST
72 Chevy C10 Cheyenne
00 Ford F-350 Super Duty 7.3L
09 Dodge Challenger SRT-8
10 Ford Expedition Limited
kilomanjaro is offline   Reply With Quote
Old 11-05-2011, 08:00 PM   #2
JimKshortstep4x4
Re: Clutch Fork Install Question
I have not had to do it but it seems like if you were to slide the transmission/transfer case rearward a little bit then you could install the clutch
fork. If you swap out the bell housing to engine bolts with longer ones then you can maintain the alignment of the the transmission to the engine. You might get by with leaving the cross member in to support the transmission transfer case as I don't think that you will have to move the assembly rearward very far to give you enough room to snap the clutch fork onto the ball.
Just a thought, good luck!
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
