11-05-2011, 05:53 PM | #1 |
It followed me home?
where to route air line to front bag?
Where have you guys drilled holes to route air line to your front bags? And did you use a stright or 90 degree fitting? Pics would be great
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
11-05-2011, 08:26 PM | #2 |
Re: where to route air line to front bag?
We were looking at this yesterday on my truck. I think we are going to drill a hole on the back side so the line does not have to go forward and then curve back. I'll take a picture on Monday of the results.
11-05-2011, 11:42 PM | #3 |
Pics please.
11-06-2011, 12:12 AM | #4 |
On my 68 w/the notched OE x-member, I ran 90° fittings off the top of the bags toward the center of the x-member. At the rear on the pass side of the x-member, I drilled a hole to feed both L/R airlines through. The airlines were secured w/cushion clamps inside the x-member. Where they exited the x-member, I had them inside of a piece of rubber hose for protection. From there, they just followed the brake & fuel lines down the chassis.
11-07-2011, 05:06 PM | #5 |
I used a 90 deg fitting on the bag. I drilled a hole under the engine stands from the bottom side. Its pretty much a straight shot to the bag, plus i can get my fat ass arm in there...lol
68 C10~ LS1/4l65 |
