Old 11-05-2011, 06:07 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Where to get these lines??
Does anyone know where to get the braided lines on this orange ride. Check out then brake lines from the master cylinder to the bulk heads in the frame.. Anyone know if this is a kit?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-05-2011, 06:22 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Where to get these lines??
Do you have a hose assembler/provider in your area - serving the aircraft and racing industries? Some of the AC and powersteering hose makers often provide the smaller teflon line service, as well. There are a few in my area such as Bonaco, XRP, G and J Aircraft, etc., who will custom make -3 AN and -4 AN teflon hose assemblies with various degree ends (45, 60, 90, 120, etc. degree). Or, you can invest in some of the tools (cutter, braid separator and olive installer), and buy bulk teflon hose and ends to assemble custom lengths yourself - it's not too difficult. Here's what the braid separator looks like:
http://automotive.become.com/earls-0...--sc1369457597
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 11-05-2011, 06:44 PM   #3
cdowns
cdowns's Avatar
speedway motors has different lengths and fittings available
Old 11-05-2011, 08:22 PM   #4
C4 Metal Werks
C4 Metal Werks's Avatar
If you know which fitting diameters you need www.spieglerusa.com has DOT approved custom lines with a lifetime warranty. I've used them for years. Super knowledgeable and friendly.
C4 Metal Werks is offline   Reply With Quote
