11-05-2011, 07:37 PM | #1 |
Killswitch, Engage!
no, not the awesome rock group. ive been doing alot of reading around and it seems that these older trucks appear to be pretty good targets for knuckle dragging genetic defectives who some how think its ok to take things from other people who work hard and contribute to society.
so i was talking to my sisters husband and he mentioned wiring a switch to the coil. he didnt really know what all i would need to do so i figured id pick some brains. i have the switch, it has two blades on it, its either on or its off. its rated at 10A 277vac 20A 125vac 3/4hp. will this switch work? then i was just wondering how i would go about wiring this switch in? would it be better to wire it into the coil or into the ignition switch? eventually i would also like to get a battery disconnect switch put somewhere, mabye in the cab itself. but for now, i figured the smaller kill switch wouldnt be as noticeable to a thief whos trying to hurry and not get caught, thereby buying me some time. i figure if nothing else, i could always remove the coil to cap wire, but then again a smart thief would notice its missing and replace it, with say, the #1 plug wire and drive off with a dead cylinder. heres to keeping them safe in the driveway!
'69 c10 longbed granny 4spd 292 "Behemoth" '67 c10 longbed granny 4spd 292 "Burzum" some pictures of my work in progresshttp://photobucket.com/zaeea R.I.P. Corey "Flattus Maximus" Smoot 11/3/11 You will be missed. Your sound lives on. |
11-05-2011, 07:48 PM | #2 |
Carpe manana
Re: Killswitch, Engage!
I drilled out a clutch hole delete plate and affixed a keyed switch that was inline with the distributor. The switch is hidden behind the carpet and easy to access.
Whatever you do make sure the hood is secured with a chain looped around the grill support or fab an in-cab release.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
11-05-2011, 10:57 PM | #3 |
I was thinking about hooking up a magic key to the ignition myself
1967custom |
11-05-2011, 11:15 PM | #4 |
Being a BMW mechanic I wouldn't want to run that current through a switch. I'd wanna run it through a relay operated by the switch. You could simply run an inline fuse and just pull that fuse (30 amp?) when you don't want it to run. Just make sure you keep a spare close by so you don't get stuck. Theft is a moment of opprotunity, no thief is gonna want to spend the time to diagnose a no-start. If it were me I'd buy a switch, go to your house, break in, unplug the ignition connector, plug in my own switch and take your truck. If it didn't run I'm not gonna try to figure it out, I'm gonna leave. Higher end thiefs just tow them.
Pulling the coil wire is a good idea, if it sit for longer periods, pulling the rotor is even better.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
11-06-2011, 01:46 AM | #5 | |
The switch to relay sounds like a nicer option, but potentially, more easily defeated (quick look under dash...there's a switch....flip it....try starting again. Even if a theif finds a missing fuse (unlikely) even he is SOL unless he has one with him. Hidden secondary keys under carpet sound like the best choice to me. All of the above are for short term. Like Bmer says, pulling rotor a good choice for longer term. |
11-06-2011, 10:30 AM | #6 |
I'd like to get some sort of gps tracker. Heard something about the "cheap cell phone trick." What is that?
11-06-2011, 12:30 PM | #7 |
Check out the link below from Bosch it has many ways to add kill switches using relays. For example having to push the cigarette lighter before truck will start. The kill switches start on pages 13.
http://sonolithics.com/files/bosch.pdf
In some foreign language "merge" means to stop and turn your head left. My build page http://67chev.shawwebspace.ca/ |
11-06-2011, 12:52 PM | #8 |
I had a key break off in my 91. Luckily the steering is unlocked. What I did was hook up a switch for the ignition and replaced the cigarette lighter with a push button. Close the ash tray and you never even know its there. It would be pretty easy to hide a switch under the dash where only you know where it is but nothing is fool proof. Make sure you lock your hood. If I was a theif I would just pop the hood and hook a wire from the battery to the coil and carry a hand held starter button to hook between the battery and starter and be gone.
Posted via Mobile Device Last edited by a_barth; 11-07-2011 at 09:22 AM. |
11-06-2011, 01:38 PM | #9 |
its all about the +6 inches
I plan on installing a ford type solenoid hidden in the frame rail inturupting the main battery power. To activate it, I have considered a small switch hooked to the brake pedal. Pedal down, solenoid activated, turn the key like normal. If you don't hit the brake, then the starter will just click like a dead battery.
The beauty of this is no one will notice it. Your friends or even teenage kids (like no teen has ever taken off in dad's car for a joy ride) will never see you tap the brake pedal as you turn the key, but when they try to start it, it'll have a dead battery as far as they can tell. Even if they try to jump it, it'll still be dead. (won't stop a push start if you have a manual trans) |
11-06-2011, 01:46 PM | #10 |
i also read about the cellphone gps tracking method! i think i still have the thread open somewhere, ill try to link it.
http://67-72chevytrucks.com/vboard/s...d.php?t=464964 basically you get a cheap prepaid cellphone that has gps capabilities and java, and download an app, then you can track the cellphone through its own gps through the app's website for free. i am defianatly considering this, because i could wire the phone charger into the trucks 12v system and never have to worry about the phone going dead. ton of good ideas here. thanks folks!
11-06-2011, 07:53 PM | #11 |
There are many places to wire a toggle switch in but if money isnt an issue, there are some cool high-techy options.....http://www.autoloc.com/catalog/Ultra...e-Start-System
I like the idea of a completely hidden switch maybe inside the cluster surround?
1949/1954 with LS swap-yeah! http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos |
11-06-2011, 08:10 PM | #12 |
They use to sell a fuel shut off that used a key years ago..that would be a better move cause a coil..cause if they hot wired it & get no spark..then it not hard to know what's up..with no fuel..she'll jus spin..`
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
11-06-2011, 08:58 PM | #13 |
I dun gradjiated collij!!!
Without getting into too much detail on an open web forum..... if they want my ride(s) they had better bring a tow truck.... multiple kills for multiple systems, all remote coded.
Built NOT Bought. Viper Red 1971 LWB C10 355 Vortec W/700R4 4/5 drop AKA Screamin' You are missed!
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! |
11-06-2011, 11:00 PM | #14 |
I hope the car stealers don't read this thread jejejejejejje
11-06-2011, 11:07 PM | #15 |
I also have a killer switch that only works if I push a button and turn the switch to start at the same time at my truck.
Also at others cars my electric mechanic friend did install an alarm that works only if the doors are open and doesnt work with remote control but it had a hidden switch that I turned of before I open the door. |
11-06-2011, 11:10 PM | #16 | |
I'm gonna use the extra remote turn on of my radio. you know the one that powers up the amps or power antenna.. and as seen as I'll have the radios face.. no power to the starter.. yes easy to bypass , but there will also be an ign kill.. a ford tank switch works good too.. front tank on, it start, rear on , dead |
11-06-2011, 11:55 PM | #17 | |
thats what im talkin bout willis! ive had more than a few discussions about wiring in a few relays here and there, but nobody ever had it on paper... or e-paper lol. so i think the one i like best is the one that utilizes the cigarette lighter, and still allows me to use it, together with also having a hidden switch somewhere. my biggest concern is, if our would be thief did his homework and had his lil remote starter setup like BMERDOC had mentioned, would he still be able to bypass the entire setup? i ask cause i havnt been able to find an accurate wiring diagram and do some sketching of my own. anyone know where an accurate wiring diagram for a 69' c10 without A/c can be found? the best i got is a haynes book of lies. im also very interested in getting either a chain for my hood or some such locking mechanism to keep my battery in, and would-be thieves out. anyone have a link to a thread that goes over this? my house is in the not-so-great part of town. im even afraid to leave it in the parking lot of wally world during the daytime. so i figure removing the cig lighter is alot easier and alot less conspicuous than removing a rotor or a plug wire. thanks again for the great ideas folks!
11-07-2011, 12:49 AM | #18 |
what i did i use a ford starter sylonoid (sp) and wired it to my headlight dimmer switch and also use marine termanals for the batt to allow ease of disconnect for winter storage. had a lowlife brake into my 66 and tryed to start it and they did alot of damage to the switch but the van stayed home
a wise man once said "There are only two real rules to life... 1 - Don't sweat the small stuff 2 - Everything is small stuff |
11-07-2011, 01:03 AM | #19 | |
and as far as the "getting around the starter kill" with a cheap remote switch a low life might carry, if you kill the ign it not start they are not gonna spend all night try'n to get it going, cause if they do.. nothing short of chaining it to the ground is gonna stop them. |
11-07-2011, 09:22 AM | #20 |
Kill switch to the ignition, battery disconnect, and a hidden fuel diconnect are about as safe as your gonna get. Add in an alarm and a set of flowmasters, glasspacks, or whatever your choice and even if they do get the truck started you'll know it and if they don't find the fuel disconnect they won't make it far. Then they have to deal with me chasing after them and nobody likes a pissed off redneck in his underwear wielding a gun at 2:00a.m.
11-07-2011, 10:38 AM | #21 |
1965 Chevy C10, 2005 4.8L/4l60
I dont think anyone can really prevent theft of their vehicle, but if you make it more difficult the lowlifes will move on to something easier.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-07-2011, 11:19 AM | #22 |
A lot of great ideas here. I have been a cop for 25 years and have never arrested a car thief with a BS or Masters degree. What ever you decide to do, make sure it is well hidden or camoflaged. It doesn't have to be elctronically complicated. The thief is not going to, or not for very long, try and decode the issue of it not starting. When I get mine back together, I'll use some of these ideas. If Memphis Raines lives in your area the GPS is your best bet. Great thread!
11-07-2011, 11:31 AM | #23 |
I'm going to buy a rabid put bull named killa, that will sleep
In the truck at night. Let's see those puckers faces when they wing that door open! Lol I am paranoid about this, I've had scrap guys sneaking around the house, I live in the back 40, so most of my stuff is garaged or way out back. But those buggers are persistent as I have a crapload of junk cars. I put in 2 bullet cameras, alarm in the garage, and I block the entrance of my garage and storage area with either the wrecker or big betha (John Deere 410 4c4 backhoe) if the get by those to, let them have it, I don't want to see the loader that dragged that backhoe around. Lol Posted via Mobile Device
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
11-07-2011, 11:34 AM | #24 |
11-07-2011, 12:05 PM | #25 |
Yeh may wanna be careful, with the way things are today you'll not only get arrested but probably get sued by the thief for exposing your self and have to sell the truck to pay for a settlement.
