Old 11-06-2011, 02:00 AM   #1
slick copper
slick copper's Avatar
Rear Spring Swap How To????
If there is already a how to please post a link for me. But I have a set of chevelle springs I want to swap out to get a 3" drop in the rear of my 67 LWB. Just need some pics and how to on swapping these suckers out! Someone told me you just unbolt and swap then rebolt. I haven't even looked yet, but figured better safe than sorry!
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline   Reply With Quote
Old 11-06-2011, 11:09 AM   #2
SCOTI
SCOTI's Avatar
Re: Rear Spring Swap How To????
That's about it..... unbolt the shocks, unbolt the springs, swap them, & bolt everything back up.
I'm not sure if you've been warned, but you may not get 3" drop from those Chevelle springs. I installed some A/G body (Chevelle) springs in the rear of one of my trucks & got ZERO drop. It all depends on how much 'sag' your current springs have.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-06-2011, 12:54 PM   #3
slick copper
It looks like on my truck the PO used this truck for hauling/pulling a trailer. He had a rear hitch on it, coil over shocks, and looks like newer heavy duty rear springs (maybe from a C20?). So I'm fairly positive this'll drop me some anyway. Also gonna get some new regular shocks to swap out with.
Guess I need to lift it by the frame then, unbolt one side at a time, swap, then do other side then?
Went out and looked at it a few minutes ago, looks fairly simple. Hate when I say that though. Means it's gonna take twice as long as I would think!
Raymond
Old 11-06-2011, 08:47 PM   #4
slick copper
Got 'em! Took me more time finding blocks and getting it jacked up more than anything. Only took me about 30 min a side at the most though. Pretty easy, just jacked up my rear (one side at a time) placing the jack on the frame to take the load off the suspension and unbolted each bolt in the top and bottom of the spring. Removed and put the spring cups in the other springs and bolted it in. Easy enough. Here's pics for you of what I did. Thanks guys.
Raymond
Old 11-07-2011, 06:40 AM   #5
big_al_71
big_al_71's Avatar
It is super easy now is time to lower that front....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 11-07-2011, 05:40 PM   #6
tubbedII
needs more $$$
tubbedII's Avatar
Once that front end is down, it's gonna look good. That's a great looking truck you got there!!!
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 11-07-2011, 06:26 PM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
Cut a coil...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-07-2011, 10:51 PM   #8
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
Attachment 824526
Attachment 824527
Looks like you netted about 5" of total drop!
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 11-08-2011, 07:28 AM   #9
slick copper
Yep got 5" from previous! I was only expecting about 3", but I love the way the rear tire looks in the wheelwell now. Gonna attempt cutting the front coil this weekend. Probably do one full coil = 2" drop. I'll put a pic on here for ya when I get it.
Thanks for the compliments guys! Can't wait to do a full restore though.
Raymond
