11-06-2011, 06:51 PM | #1 |
the best part cleaner
i have a 65 c10m and what to clean all the gunk and grime of the front the truck with remove all the big part . should i buy and little pume would work any ther ideas
11-06-2011, 07:07 PM | #2 |
Re: the best part cleaner
when i cleaned mine i used a putty knife to get the big stuff off and then used oven cleaner and a pressure washer! it worked for the most part, then i used a wire wheel to clean the rest! theres other ways of doing it but thats what i did!
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
11-06-2011, 07:31 PM | #3 |
I used a lot of Simple Green when I was power washing my engine bay
11-06-2011, 08:07 PM | #4 |
I recently brought my truck to a detailing shop and had them put it on a lift and steam clean the entire undercarriage. Cost me $50. I am sure that you could talk them into doing any parts you wanted for not a lot.
66 Chevy C10 Stepside LWB My Build Thread 75 Harley FLH 84 Mercedes 300TD Diesel Wagon |
11-06-2011, 08:09 PM | #5 |
i have used i think it is called something purple. worked really good. got it at wallmart for like $4 a gallon. helps alot if you can get a pressure washer also.
11-06-2011, 08:26 PM | #6 |
SIR
...castrol "super clean".... Use gloves it is caustic (removes skin) & eye protection!!! Let it soak on the hard stuff & rent a pressure washer & clean it up!!!....good luck.
66long low fleet http://community.webshots.com/user/LVNR66 |
11-06-2011, 09:48 PM | #7 |
Rollin' Old Skool
probably Purple Power...i have some of that, as well as Simple Green...i did the same process as "chad64chevy" on my front suspension/frame
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
11-07-2011, 02:08 AM | #8 |
Start with castrol Super clean, available at walmart, along with gloves, safety glasses or face shield and an assortment of stiff nylon bristled brushes and assorted scrapers.
once the big chunks are off, pressure wash, then brush remaining bits of remaining gunk with aforementioned castrol super clean and assorted brushes. Pressure wash again. some paint may be removed during these processes, if the idea is to get down to bare metal then the use of oven cleaner will accomplish that. if using oven cleaner by all means spend the money for the good stuff (not the dollar store junk). And follow all safety precautions on the can. Rinse, lather, repeat. Stop when frame has been cleaned to the point your happy.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself? |
11-07-2011, 04:03 AM | #9 |
I use the stuff called Oil Eater that is sold in five gal jugs at Costco. It seems to work pretty well. Also, If your going to use oven cleaner, by all means keep it away from anodized alum trim. It'll wreck it in seconds.
11-07-2011, 07:57 AM | #10 |
Pinesol also works well.......
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
11-07-2011, 08:24 AM | #11 |
Check The Champ, Demonstrator
Watch out where you do it, this residue will stain your Asphalt or worse yet your Concrete Paving Stones and could yellow your grass. Do it at your parents house, it'll give them something else to be disappointed in you for but will continue to love you. Purple Power is bio degradable.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
11-07-2011, 09:30 AM | #12 |
Hollister, CA.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
11-07-2011, 09:42 AM | #13 |
"Where were you in '62?"
Same here....
Purple Power Degreaser. And for rusty bolts and cleaning metal parts a product that works better than WD40 is Kroil. I love this stuff. Kroil Penetrating Oil - Loosens Frozen Metal Parts better and faster than WD40. http://www.kanolabs.com/ Also check out CRC Industries Cleaners. http://www.crcindustries.com/auto/?page_id=17 http://www.crcindustries.com/auto/?page_id=42
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
11-07-2011, 10:10 AM | #14 |
Countdown Survivor
I've used about everything from gasoline to dish detergent. I find it's usually as much about technique as anything, and a bunch of elbow grease. I keep assortment of brushes, bristle, wire, etc. from stiff, to cheap paintbrushes cut down to 1" or so, sometimes I'll wrap masking tape around the metal part if I'm doing like interior plastic or such I don't wanna scratch. I frequently use the local carwash for larger portable stuff.
93 Yukon 89 Silverado Z71 SWB Sport 91 K 2500 Silverado "Lobuk-Worktruk" A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO. Gettin' old ain't for sissies. |
11-07-2011, 11:49 AM | #15 |
I am a Referee of life.
I always use the local carwash.I don't think my parents could be any more disappointed than they already are.I needed new folks to disappoint.
I use a degreaser(usually "Right Stuff') and most of the same as above.I have found the main ingredient to the clean recipe is PERSERVERANCe.It takes time and effort to really get one clean.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-07-2011, 05:16 PM | #16 |
I use simple green an purple power usually an they work good, I like simple green better. I've also used "power foam" from ams oil to clean up my motor, its more spendy but worked better, and you can also spray inside your motor to clean it out when its running.
1969 Chevy c20(Miss Hackjob) |
11-07-2011, 05:28 PM | #17 |
i have always used kerosene or deesul fuel with a stiff brush
11-07-2011, 07:42 PM | #18 |
the pollock
what is affordable is purple power.. i buy it 5 gallons at a time now and put it into a pump up sprayer and my pressure washer.
on a cooler (not frozen) day apply every twenty minutes to get a dang good soak.. then pressure wash the crap outta everything. good luck.
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
11-07-2011, 07:49 PM | #19 |
Moderator
POR Marine Clean works better than anything I have ever used. It is like Simple Green x 1000. Simple green is great for maintenance, but it doesnt touch 40 yr old caked on junk.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
11-07-2011, 09:05 PM | #20 |
easy off oven cleaner
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
11-07-2011, 11:12 PM | #21 |
Grandpa in the rustmobile...
dg oven cleaner best bang for the buck
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
