Will a rear sway bar work with under bed fuel tank
I have a 66 short bed in which i have relocated the fuel tank to under the bed. I would like to install the front and rear sway bar set from CCP. Does any one know if the tank would interfear with the rear bar?
Thanks Posted via Mobile Device |
Resistance is Futile
Re: Will a rear sway bar work with under bed fuel tank
Im not certain, but most swaybars are in front of the rear axle on these trucks. Shouldnt interfere unless you put the tank in there.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
