Old 11-06-2011, 09:01 PM   #1
Leadfoot Lambert
Leadfoot Lambert's Avatar
Fleetside bed question
I started working on the bed of my truck this weekend, I have to change the drivers bedside because its junk, I also have some body work to do on the pass side but I figured I should probably make sure the bed is on strait and square before I start. Here's where the fun starts, it seems the bed is narrower than the cab by over an inch! There is a slight bow to the head board but its not bad enough to pull the bed side in an inch, so what gives? Is the bed supposed to be narrower than the cab? the cab is on strait and has all new mounts, the nose is on with new radiator support mounts and a rust free California radiator support, everything in front lines up very well. the bed could be on crooked at the front and maybe I should move it over to split the difference but the drivers side lines up near prefect now. Here's some pics any suggestions appreciated
65 Chevy short fleet 350 5 speed, soon to be LSX powered
65 F100 short fleet
91 Heritage softail
94 Fatboy
11 Softail Deluxe [wife's bike]
13 Streetglide
http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz
Leadfoot Lambert is offline   Reply With Quote
Old 11-06-2011, 09:28 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Fleetside bed question
yes stock I think it is a tiny bit narrower, maybe 1/2 inch each side.
if no one else chimes in I will check out my 65 in the morning and get you an exact measurement.
Old 11-06-2011, 09:29 PM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Aerodynamics, As the air flows along the side of the cab it shouldn't get caught up on the front of the box so they made it slightly narrower. lol
Everything with these trucks is approximate. Divide the difference between the two sides and if anyone comments, see above.
Old 11-06-2011, 09:41 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
Yes, generally speaking, the bed is a bit narrower than the cab.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 11-07-2011, 07:22 AM   #5
tazattitude
tazattitude's Avatar
I know my bed is also a little narrower. More like 3/4" on each side
TAZ
BUILDS
1966 GMC Suburban
1963 GMC Suburban Patina frame-on FOR Sale
1966 C10 Short Bed (2010-11)
Monthly Updates
2015 C10 Pics with my '72 Montego GT 429/521 build
1963 Pro Street C10 back halved. Frame off I did back in 1990
Pics / Video
tazattitude is offline   Reply With Quote
Old 11-07-2011, 07:52 AM   #6
Rich 5150 69
Rich 5150 69's Avatar
Mine is the same way...thought it was just my truck...I just split the differance,.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 11-08-2011, 10:08 PM   #7
Leadfoot Lambert
Thanks guys, I guess I'll split the difference
65 F100 short fleet
91 Heritage softail
94 Fatboy
13 Streetglide
