Old 11-06-2011, 11:09 PM   #1
chevyhed53
drop the rear
Just bought a '56 stepside, and need to lower the rear maybe 3 inches. Previous owner added coil springs. Coils that are there are six coil units. What would you recommend to drop the rear 3 inches? Thanks. sr
chevyhed53 is offline   Reply With Quote
Old 11-07-2011, 05:45 AM   #2
dmack91
dmack91's Avatar
Re: drop the rear
You probably need to be a little more specific. Did the PO replace the stock leeafs with coils or just add coils over the leafs for extra load capacity?
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 11-07-2011, 09:11 AM   #3
chevyhed53
Re: drop the rear
He added coils over the leafs
Old 11-07-2011, 09:37 AM   #4
entourageguy
Yellow truck club
entourageguy's Avatar
Re: drop the rear
cut out the springs and move the axle to the top of the leafs with a flip kit.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 11-07-2011, 09:49 AM   #5
Rude Dude
Rude Dude's Avatar
Re: drop the rear
I bought 1/4 think bottom plates for leaf springs from Four wheel drive place on-line cheap for Jeep, I think it was less than twenty dollars for the pair, and Bought U Bolt take off's from a Truck Accessory Shop for $10 and Saddle that go to the bottom of the rear end for $8 from trailer place. I use all these items to flip rear end. Way cheaper than after market kits and rear shocks from a 66 ford econoline (KYB's) for $60 each on Amazon. They are shorter for drop. Flipping gives you a 5-6 inch drop. You can see it on my build
Rude Dude is offline   Reply With Quote
Old 11-07-2011, 10:43 AM   #6
mknittle
mknittle's Avatar
Re: drop the rear
there seems to be some confusion.there are several ways coils could be used. could you post some pictures?
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 11-07-2011, 12:29 PM   #7
chevyhed53
Re: drop the rear
Thanks. I will try to go that route.
