Old 11-07-2011, 12:00 AM   #1
Meatman
Meatman's Avatar
Strange hole in firewall.
Only had my 68 for about two weeks now. Been going over her with a fine tooth comb. Discovered this today. PO had put tape over it on inside of cab. What is giant hole for? I cant figure it out.
Daily-94 K2500 350 5spd extended cab longbox
Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack.
Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881
My 01 TA and 88 Formula hide in the garage. :-)
Meatman is offline   Reply With Quote
Old 11-07-2011, 12:08 AM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Strange hole in firewall.
Looks like the hole for a clutch rod. Automatic trans trucks used one of these at least to early 69 http://67-72chevytrucks.com/vboard/s...d.php?t=492610 Later trucks had a metal disk secured by screws top and bottom. The plastic plugs tended to "blow out" when the doors were slammed since they were attached from outside the cab.
FirstOwner69 is offline   Reply With Quote
Old 11-07-2011, 12:17 AM   #3
Meatman
Meatman's Avatar
That was my one guess as to what it could be. I just didn't figure the hole would be there if truck was an auto originally.
Old 11-07-2011, 12:28 AM   #4
vectorit
What?
vectorit's Avatar
Clutch rod.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 11-07-2011, 12:49 AM   #5
CTENTA1
Registered 1971 K5
^^^what he said^^^
CTENTA1 is offline   Reply With Quote
Old 11-07-2011, 01:07 AM   #6
stich626
look for 2 screw holes at the bottom of the dash about 3 1/4 apart..
the old chapman cable lock..
stich626 is offline   Reply With Quote
Old 11-07-2011, 05:53 AM   #7
OhioDan
OhioDan's Avatar
Does this help?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 11-07-2011, 03:52 PM   #8
Autoblueprint
Autoblueprint's Avatar
Post Re: Strange hole in firewall.
There is a male/female four prong molded connector that fits this hole...it connects a 4 wire interior wire harness to the exterior wire harness for the turn signals, brake / running / reverse lights. I believe the wire harness colors are light green, dark green, yellow and dark brown if memory serves me correctly...it looks like you can see the exterior harness in the 2nd photo above and to the left of the hole.
John Harlowe
1971 CHEVROLET C-10 FLEETSIDE LOWERED
Autoblueprint is offline   Reply With Quote
Old 11-07-2011, 03:59 PM   #9
leddzepp
Moderator
leddzepp's Avatar
That hole is further over towards the passenger side, and up higher. The hole in question is for the clutch rod, as stated above.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 11-07-2011, 07:51 PM   #10
longhorn70gmc
longhorn70gmc's Avatar
This is a great question to ask. I go the same answers as to the pictures show and I discovered it on a 1968 LWB Chevrolet. I also found the rubber grommet that goes there as well still on the truck. Picture in your mind a Oval shaped like an egg and then it has a rubber sheath coming off of it about 2 to 3 inches long. This is what the linkage was routed through. I view the hole as godsend, so I don't have to make anymore in my fire wall. I am currently using it for my Vacuum gage line and when I finish the TAC it will also go through this whole. The grommet is hard to find because I admit I have been trying everywhere including the internet, but removed the old grommet from that 1968 and have refurbished it with High Temp Black RTV to make it fresh again until I find a nice new one. I am going to go find some kind of packing to fill it when I am done to keep the rodents out of the cab. I just redid my seats. Good Thread and am glad you asked.
R/
Billy
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 11-07-2011, 09:22 PM   #11
cleszkie
cleszkie's Avatar
That is the rarely optioned spark plug inspection port.
cleszkie is offline   Reply With Quote
Old 11-07-2011, 11:55 PM   #12
Meatman
Meatman's Avatar
Thanks for help guys. Now I just need to find a plug for it.
Old 11-08-2011, 02:44 PM   #13
longhorn70gmc
I enjoy the humor on this because this was such a search in trying to figure this out; thanks for the good laugh!!!!!!
R/
Billy
Billy
Hub Cap Freak!
Old 11-08-2011, 02:48 PM   #14
longhorn70gmc
For now I am reusing the original grommet I found. There has been a cotton rag stuffed in it for the past 19 years. It was always hidden under the firewall insulation on the inside of the cab like in your picture, but I noticed it from time to time from the engine bay. Can't explane why I never bothered to investigate. I have that it has to be fixed now syndrome and never did anything on it till now. Good Luck on your search. I would love to see a follow up picture of what you end op doing.
R/
Billy
Billy
Hub Cap Freak!
