quick question
What is the correct pressure rating for a radiator cap on a stock 71 350?
Also how bad is it if you are running with a cap that is lower in pressure than what is required? Thanks. |
Re: quick question
iirc the cap is 15psi.. might be 7 tho.. mine is 15
a lower cap will just lower the boil point of the coolant.. |
Re: quick question
Everyone else got any info on this.
![]() Join Date: Jun 2010
Re: quick question
For some reason 13 sticks out in my head.
Old Duffer
![]() Join Date: Mar 2003
Re: quick question
I agree with all of the above......13lb to 15lb, and for every lb of pressure you add, you increase your boiling temp three (3) degrees.
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
Re: quick question
I just had my 4 core redone in RENO NV at A-1 radiator shop and he went out of his way to tell me that I should be using a 16 PSI or higher. I asked him is it that way for SB and BB motors and he said it should be standard for the use of 4 core radiators. I hope this helps you.
R/ Billy
Billy ![]() ![]() 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! ![]() ![]() ![]() I'M IN THE MARKET...AS IT WERE! |
Re: quick question
Helps me alot. Thanks for all the input. The PO of my truck put a 7 PSI cap on it. I am always running hot and losing water thru the overflow after long trips. I think the correct PSI may solve my problem. Thanks again.
![]() Join Date: Nov 2001
Re: quick question
I have a 14lbs Stant Lev-R-VenT on my 4 core radiator all for my L6-250 350 Turbo Auto Trans. Thats what the man at Fingers Radiator Shop recommended.
Re: quick question
I forgot to mention my four core rad came out of 69-70 pick-up v/8 350 -350 auto trans with 14lbs cap , it all looked origenal.
