Which Way To Go??
1957 3100 with a 283. Truck will not be used to haul or tow. Just want a reliable cruiser that can ride thru town or jump on the highway without worry.
Current set up is a TH350 with original 57 rear and 3.90 gears. 40-50 MPH = about 2500 RPM so I usually just stay off the interstate and even in town, my gas mileage is suffering. My question is should I go with a different (6 lug) rear end or keep it and swap out the TH350 for a 700R4. Would like to hear all opinions and advice. Thanks in advance.
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
Re: Which Way To Go??
If your looking for better mileage I think the transmission swap would accomplish it better than a rear gear swap.
IMHO if you do the gears only your going to see a drop in driveability around town. The best case would be to do both. Just as a reference my brothers 62 f**d with a modular V8 has a 4 speed auto with 3.25 gears and gets 20 mpg and is real easy to drive around town and on the highway. Kim |
Change the transmission. 4th gear is .70 so your 2500 rpm will drop to about 1750. Also has a lower 1st gear for quicker off the line response.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
The trans change would probably give you the best all around driving truck. It would have decent highway manners but still be able to pull a trailer or have good low end acceleration.
I went with a early Camaro 10 bolt 273 gears, with a turbo 350 I run 70 on freeway all day long. Easy to find, 2" narrower than stock so you can run a deeper rear wheel. Will need to install new spring perches but you will need to change things to run 700R4, more cost effective I think to do rearend. Oh yea it gets alot better mileage too, my driveability is great around town, will do a first gear burnout.
Truck's just for the fun of it. ![]() |
#6 | |
You can also purchase a 3:38 to 1 ring gear and pinion for your stock rearend.
http://www.yukongear.com/ProductDetails.aspx?ProdID=823
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
![]() ![]() Join Date: Nov 2008
Pretty sure this is my gear ratio too. I have a (too) cammed 283 with Edelbrock dual plane intake and Holley carb, headers. 10 bolt rearend and I can freeway drive with no issues at all. Older Chevy 5 x 4-3/4", 5 lug pattern.
