Stirrer of the Pot
Rear trailing arm bag setups
what choices are there other than BOA and utilizing the arms? I was looking at the porterbuilt tubular trailing arms, says 3" drop. Seems like a good investment while static. Anyone go with a cantilever setup on these trucks? I'm wondering if something like KP Link's bolt on canti setup would work on a 60-66?
Stirrer of the Pot
Re: Rear trailing arm bag setups
maybe this is a better question. what changes on the rear that makes this a 63+ setup? I thought 60-62 was same rear setup as 63+?
http://www.kplinks.com/product.php?p...&cat=50&page=1 |
what suspension do you have ?
The only reason to go Cantilever is if you are going really wide on the rear tires and you want to really drop the rear of the truck, What are you trying to accomplish ? |
Stirrer of the Pot
1/2 ton trailing arms now. I thought the canti had more lift and a better ride? I had a parallel 4 link with BOA on my last truck, I'd like to lay frame with a bolt on solution if possible. I'm capable of welding, but I like the cleanliness and laziness of a bolt on pre-designed solution... any suggestions?
#5 | |
It's Better With Nitro
#6 | |
Stirrer of the Pot
with that '61 frame, is there a bolt on rear air setup you'd recommend? then again, I'll have to verify this is a '61 frame... after climbing under it tonight i realized its already been body dropped by way of cab mounts, the front sus is already converted to coil and power disc. so I don't know, rear could be anything. I'll get pics and see if someone can help identify. VERY excited about this truck ![]() |
Stirrer of the Pot
I think i Just found out its a 68 frame. that should make life easier
![]() I may go with a weld-in notch though after all. would really prefer bolt, but not sure I want to spend $400 on the notch. seems pricey. http://www.kplinks.com/product.php?p...&cat=81&page=1 |
The real limiting factor on these trucks is the front end, unless you do a z on the frame, cup the a arms, or go to a full front dropmember you will not drag frame, after you get the front of the truck to the ground then you will have to change the rear, Kieth
If you want a inexpensive drop add 2" spacer block between the trailing arms and the rear end, I got mine from Boris for $60.00 then you will be able to take advantage of your notched frame. Kieth http://kieth.smugmug.com/Trucks/66-G...8_QhxZCfT-A-LB |
meowMEOWmeowMEOW
Ok, what makes you think it is a 68 frame?
The disc brake front ends (a arms and spindles or the whole xmember) can be swapped on the 60-66 frames pretty easily. Is the truck still a 6 lug, or has it been converted to 5 lug? You mention BOA (bag over/on arm, last time I built an air ride setup), then mention the 60-62 frames, which would be leaf spring and not have the trailing arm rear. If you can weld then you could run pretty much any system you want. Cantilever will get you more lift, and usually let you do so with a slightly smaller bag. Requires more fab work, and math. IMO to have the most ease, the most articulation, and one of the easiest would be a 4 link. Even easier, a 3 link, but u loose a little bit of side to side. Thorbeck bros, aka suicidedoors aka Quality Air Ride now...have some really nice diy kits for stuff like that. If you call them up and tell them what you want to do; usually one of them can put a nice setup together for you.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Stirrer of the Pot
is this what you mean by cup the arms?
http://67-72chevytrucks.com/vboard/s...ng+arms&page=3 how much lower will that get the front? or... how close to concrete? I'm wondering if its worth it or if I should just wait till I can afford the dropmember. |
#11 | |||
Stirrer of the Pot
#12 | |
1. rear bridge kit (suicide doors) firestone 9000 series air bags 2" spacer blocks std trailing arms 2. front of truck 8' firstone bags , 2.5" drop spindles, cupped A arm like you showed in your link to coulters build. We have not started the front yet, will have the later model disc brake set up tomorrow so we will modify the a arms then install the disc brake crossmember and drop spindles put on the cragar wheels and see how low she will go. Kieth 3. after this is done we are considering dropping the body 2" but will wait to see how low we can go on a budget Kieth |
#13 |
Stirrer of the Pot
I definitely want to see your build when you get that front end going Kieth. how much camber do you expect after cups and spindles?
with this blocked/oem trailing arm setup, what is the leading hindrance to going lower? the trailing arms hitting the frame, or the front suspension work? |
#14 |
Stirrer of the Pot
with that rear bridge kit, you are going BOA?
#15 |
meowMEOWmeowMEOW
60-63 were leaf 64-66 were coil spring usually; you said the frame is a 68 so its a different story.
#16 |
Stirrer of the Pot
yes the '61 I have now is on a '68 frame. I just thought the other part you mentioned about 60-63 having leafs was odd. I'm not saying you're wrong, but I had a 60 with trailing arms and coils, and I currently have a '62 with trailing arms and coils. I learn something new every day.
#17 |
Stirrer of the Pot
Kieth I was thinking about your setup. In the short term, I could notch and bag the rear without the dropmember, cup the front, and get the truck down to within 2 inches or so for under $1k probably.. and always add dropmembers later without having wasted anything I think.... maybe that is the way to go short term.
#18 |
my 62 had trailing arms
#19 | |
When you cup the A arms do not extend the bottom of the box below the edge of the A Arm because this can cause problems with clearance. I will let you know what kind of problems we run into as the build proceeds. Kieth The build by Coulter should give you some insight into how the truck will sit. I am also looking into a simple body drop since 1 or 2 " is very important. It looks like one could add a deep trans tunnell, then lower the cab mounts, front radiator mounts and front fender mounts and then the bed mounts without a lot of trouble. Z-ing the frame accomplishes those things but is just a little too radical for me......Kieth ![]() |
#20 |
BOA does that mean Back of axle ? yes we are going behind the axle on the outside of the frame or it could end up on top of the axle after we drop the front the ride height will be set (since that is the limit) and we will then position the bags in the rear to match the front of the truck. Until you start one of these projects you do not know how much actual thought goes into it. We need to set the ride height of the front bags to their proper height
8" see where the rear bags have to be set so they are withing their travel range 8 to 8.5" and then make sure the rear bags do not collapse farther than 4.5" when fully lowered.....so it is going to be a juggling act. Kieth |
#21 | |
Jason at AVS has some killer deals as well as Boris Here is what you need: 1. 2.5" drop spindles (to fit whatever front end you have with disc brakes) 2. 2 firestone (slam specialties) 8" with 12" total height $319.00--#1 & #2 boris has this deal and it is great......................................................... 3. 2 top brackets for a arms (_70.00) 4. 2 Firestone 9000 series bags for trailing arms $140.00 5. Lowering block and U bolts (Boris) $ 60.00 6. Misc air line and schrader valves $ 50.00 total $619.00 Plus freight Check with Boris and Jason to see who has the best deal.......Kieth Jason AVS http://www.avsontheweb.com/home.php Boris Hub garage http://www.hubgarage.com/mygarage/way2Lo2 the nice thing about this is it can be done in stages, do the drop blocks in the rear and the rear bags....... Then do the front.......it does not have to be done all at once. Last edited by kieth; 11-09-2011 at 10:52 AM. |
#22 |
Stirrer of the Pot
when I built my last truck, we set it so full aired out was a completely compressed bag I believe, but it was laying frame. I can see a benefit to this setup, having the truck basically as low as it will go with some air still the bag may help with ride quality.
BOA I always refer to for bag over axle (so axle mounted bags rather than behind) This weekend I"ll try to take apart the front a bit and see whats going on. the truck is already lowered so I'll try to figure out how they did that, maybe it has drop spindles already... |
#23 |
Stirrer of the Pot
by the way, AVS is great. I think I have spent over $5k there lol.
and I got a tshirt. ![]() |
#24 |
meowMEOWmeowMEOW
I was a bit mistaken, the GMC still used the leaf springs when the Chevy had already switched to coils with trailing arms. Hence my confusions.
#25 |
Stirrer of the Pot
oh that would make sense
