Old 11-07-2011, 08:51 PM   #1
gunslinger
Poly cab bushing question
Replaced the cab bushings with a Energy Suspension kit. The front cab bushings have a 5/16 gap from the top of the bushing to the bottom of the cab. None of the bolts are tight yet, just the weight of the cab sitting on them. Rear of cab is resting on bushing and radiator support is resting on bushing, just not the center bushing. Had to stop working on it tonight cause of the kids, but this is going to bug me all night. Will the bushings compress and all is good?
gunslinger is offline   Reply With Quote
Old 11-07-2011, 08:53 PM   #2
litew8
litew8's Avatar
Re: Poly cab bushing question
Not energy but similar. Check my thread. Mine haven't been tightened yet.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 11-07-2011, 10:07 PM   #3
gunslinger
After some research I found out there is a difference between 1/2 & 3/4 ton cab bushings. Anyone know the difference?
Old 11-08-2011, 08:17 AM   #4
3/4t (also 1t & fwd) are taller. The mount on the frame is located lower. So,1/2t 2wd are by themselves.
Old 11-08-2011, 10:37 AM   #5
turp mcspray
turp mcspray's Avatar
Don't tighten them down to remove the gap, or you will twist the cab, making your doors not fit. Add shims so you don't put stress on the cab.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 11-08-2011, 04:31 PM   #6
litew8
litew8's Avatar
Mine is a 3/4 ton frame and some of my pictures I outlined the difference between 3/4 and 1/2 ton.
